Hi, do you have a solution for a blue ray player connected to
PT-47WX53G TV using HDMI DVI. The video just starts to play and then we get information on the TV screen and on the laptop screen: "YOUR DISPLAY ENVIRONMENT DOES NOT SUPPORT PROTECTED CONTENT PLAYBACK" Is PT-47WX53G HDCP compliant monitor?
P.S. We do speak Polish. I've notice your Polish name :)
sir DVI is only support for video you can get video through DVI not sound if your tv have no hdmi port then please purchase adapter which is called HDMI to av converter
thanks
Does the TV have a plug connection I think is called DVI. There is a DVI to HDMI adapter that also needs an audio connection on TV to work. Other option is audio and video rca cables. You may also need to change input connection to correct source, as it may not be auto for connection
i have the same tv. there is only a dvi input with separate audio inputs.you will need a dvi to hdmi adaptor to connect for hi def.hdmi is video and audio while dvi is only video.you still get the picture quality,but have to run audio rca cables also.
Yes there are a few options for you to make the link between your TV and the BluRay DVD player, first there are adapter cables made with HDMI plug on one end and DVI plug on the other end, remember that with this cable you will have to link the audio signal with another cable because DVI only passes video. Second if you cannot find the adapter cable in your area you also can use the component video(red,blue,green)instead of the other adapter cable,that is if your TV has component video ports, and again audio will have to be linked with another cable because component video only passes video signal. Good luck !
You can try out by connecting the CVBS (Yello) out from player to TV and connect HDMI out from Player to TV. Goto CVBS input on Sony TV. Select set up and you should get the HDMI Video options availble. Try to change the resulution and check for Video on HDMI source.
Which disc you were playing PAL or NTSC? PAL should work for Europe.
It doesn't have an HDMI port, only a DVI port. You'd have to get an HDMI-to-DVI cable to get a true "digital" signal on the screen, but you'd still have to do your audio with the RCA jacks because DVI is video only whereas HDMI is audio and video.
As far as Blu-ray compatible, yes and no. It's a high-def TV, so if you hook a Blu-Ray player up to it you'll be in good shape but the built-in DVD player will not read or play Blu-Ray movies.
Unless your TV is HDCP compliant (sorry, don't have to research this for you), you may not be able to watch Blu-Ray movies from your Blue-Ray player in 1080p. So first find out if your TV can do HDCP via the DVI port (i doubt it). If it can, you can get an HDMI-to-DVI adapter (you can find them real cheap off Amazon.com)
