Sentry Fireproof Safe Logo
Posted on Jan 04, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Changing the combination
I own three safes and change the combinations from time to time. I would like instructions on how to change the 3 number combination for my sentry safe.
It has a number AJ-008359 on the inside. I am currently using it but want to change the combo.
Thanks,
Ken
A1 Locksmith Burlingame
Level 2:
Scholar:
  • Sentry Expert 170 Answers
  • Posted on Aug 05, 2010
Sentry Expert
Level 2:
Scholar:
Answers
170
Questions
0
Helped
252768
Points
258
These sentry safes dial combinations are not built to be changed as they have no key change hole. Switching the order of the tumblers could be done by a trained locksmith. I would suggest buying the electronic sentry safes as these safes can be reprogramed.
3answers
1helpful
Combination rotation
3 Digit Combination Lock
31-10-31
  1. NOTE: If your safe DOES NOT have a key, skip Step 3.
  2. Turn the dial to zero.
  3. Insert your key and turn it until the plunger pops out.
  4. Turn the dial to the left (counterclockwise) three times to the first number of the combination (pass the first number of your combination two times, stopping on it the third time).
  5. Turn the dial to the right (clockwise) two times to the second number of the combination (pass your second number once, stopping on it the second time).
  6. Turn the dial to the left to the last number (stop the first time on your last number).
  7. Pull the handle down; the door should open.
3 Digit Combination Locks for Security Safes
31-10-31
  1. Turn the dial to zero.
  2. Turn the dial to the left (counterclockwise) three times to the first number of the combination (pass the first number of your combination two times, stopping on it the third time).
  3. Turn the dial to the right (clockwise) two times to the second number of the combination (pass your second number once, stopping on it the second time).
  4. Turn the dial to the left to the last number (stop the first time on your last number).
  5. Insert the key; turn right.
  6. Pull on the key while it's in the lock to open the door.
3 Digit Combination Locks for Gun Safes
31-10-31
  5. Pull the handle down; the door should open.
Electronic Locks
31-10-31
  1. Insert the tubular key into the lock to the left of the key pad.
  2. Turn the key all the way to the right until the plunger pops out.
  3. Press the five-digit factory code. The green Proceed light will come on.
  4. Pull the handle down; the door should open.
4 Digit Combination Lock
31-10-31-10
  2. Turn the dial to the left (counterclockwise) four times to the first number of the combination (pass the first number of your combination three times, stopping on it the fourth time).
  3. Turn the dial to the right (clockwise) three times to the second number of the combination (pass your second number twice, stopping on it the third time).
  4. Turn the dial to the left (counterclockwise) two times to the third number of the combination (pass the third number of your combination one time, stopping on it the second time).
  5. Turn the dial to the right to the last number (stop the first time on your last number).
  6. Pull the handle down; the door should open.
You can find more information about Sentry Safes at www.SentrySafeShop.com
I have the combination, but I forgot the order that it is supposed to be applied. IE do I start by turning left or right? How many times? then for the next number in the oposite direction, how many...
31-10-31
31-10-31
31-10-31
Electronic Locks
31-10-31
31-10-31-10
You can find more information about your Sentry Safe at www.SentrySafeShop.com
4helpful
Is pattern to sentry 1230 safe right left righ
31-10-31
31-10-31
31-10-31
Electronic Locks
31-10-31
31-10-31-10
You can find more information on your Sentry Safe at www.SentrySafeShop.com
2helpful
How do i unlock my safe with: Model number MSW 3110 Serial Number BK 706346 Dial Combination 23-93-59 Thank you. Dan.
31-10-31
31-10-31
31-10-31
Electronic Locks
31-10-31
31-10-31-10
I need the turns for sentry safe 1330 i seen it on your site and i forgot to write them down can you post it again thank you
31-10-31
31-10-31
31-10-31
Electronic Locks
31-10-31
31-10-31-10
I know the combination of sentry 1610 safe but can not open.
Are you sure that you are turning the dial correctly? 3 Digit Combination Lock
31-10-31
31-10-31
31-10-31
Electronic Locks
31-10-31
31-10-31-10
How do I open the combination lock to my sentry home safe?
Locksmiths advise these Opening instructions for sentry fireproof electronic security safes. Insert the tubular sentry key into the lock to the left of the key pad. Turn the key all the way to the right until the plunger pops out. Press the five-digit factory code. The green Proceed light will come on. Pull the handle down; to crack the sentry door open.
sentry safes opening instructions for 4 # combo locks
Turn the dial to the left (counterclockwise) four times to the first number of the combination (pass the first number of your combination three times, stopping on it the third time).
Pull the handle down to crack the sentry safe open.
Sentry safe ob0100 wont open with 3 digit com
A1 locksmith say's If your safe doesn't have a key, skip Step 3.
Insert your sentry safe key and turn it until the plunger pops out.
Pull the handle down; cracking sentry safe open.
2helpful
Need assistance opening my Sentry 1250 safe. I have combination but do I start at 0 and pass the first number then stop 2nd time around at first number then go straight to the other 2 numbers?
Locksmith instructions for sentry safes
on how to dial open sentry fire safes.
NOTE: If your safe doesn't have a key, skip Step 3.
Top Sentry Home Security Experts
Grand Canyon Tech
Grand Canyon Tech
john h
ADMIN Andrew
ADMIN Andrew
Are you a Sentry Home Security Expert? Answer questions, earn points and help others
