Main motor error
The main motor starts or changes
speed. The lock signal does not
continue for 1 second within 3
seconds.
• The main motor starts. The lock
signal is detected and operation
proceeds normally. The lock
signal is interrupted for 1 second.
Causes:
• Defective main motor
• Too much load of the main motor drive
SOURCE: ricoh color copier service code
Hello sir; Let's try to reset;
1, press "clear mode", "107", then press and hold down "clear/stop" for about 3 second.
2, touch copier SP,
3, enter SP5-810-2 pres enter.
4, press 1, then turn power off and back on .
SOURCE: what is the sulution for e541 copier machine ricoh 5832
SC 541 indicates a problem with the heating unit thermistor in the machine.
This type of inquiry requires service support from your local authorized dealer or original point of purchase. This type of service code can not be reset by the user for safety reasons.
SOURCE: ricoh copier 3813 - error e
E codes are displayed in the copy counter.To display both digits of the E code press the enter key.
E11 exposure lamp error.Possible causes exposure lamp open thermofuse open.
E12 exposure lamp error Ac drive board defective or main board defective.
