Question about Toshiba Satellite A75-S231 Notebook
Thank you, techniwiz, for taking time to acknowledge my laptop dilemma. thank you for sharing your expert insight & solution. my toshiba satellite A75-S231 is now operating fine.
  • Brett07
    Brett07 Jan 08, 2009
    dear FixYa friend,
    thank you for taking time to acknowledge my Toshiba Satellite dilemma support request. the laptop was having several malfunctions, more than just the one requested issue.
    ultimately i used the system recovery cd-rom to perform a full system recovery. my Toshiba Satellite laptop is new again.
    thank you for your FixYa support & suggestions.
    Daryl
Would like to be able to remove Vista, clear hard drive and install windows 7 to ultimatly run navigation software programs. Can this be done?
Thank you for allowing us to help, please respond with further questions and concerns
Spanish speaking available for all problems
Before you leave feedback, ensure that your concerns and problems are addressed completely with me.
PLEASE do not forget to award/PROVIDE "POSITIVE" FEEDBACK
PROVIDING FEEDBACK WILL ALLOW US TO CONTINUE SUPPORTING YOU IN EXPERT SOLUTIONS Before you leave feedback, ensure that your concerns and problems are addressed completely with me.
Hello, thank you for sharing your problem with us, I would personally be happy to provide the most accurate and up to date information for you.
1. Your upgrade can only be done as long as your laptop supports WINDOWS 7.
2. ALSO, I know that windows 7 will work but you may have difficulty in locating sound, video, and camera device drivers as most laptop manufacturers are still scrambling to get these up to date drivers for windows 7.
Jan 11, 2011 | Toshiba Satellite A135-S4527 Notebook
I've connected my laptop to my tv using s video ables but can't grt it to display. Can you help?
  • Hi, when you connect any type of external "Monitor" to your computer, the computer have to recognize that a "different" Display is attached! To "Display the (TV Monitor), do the following; (right click) on an empty area of the Desktop, in the next [window] select the "Personalize Icon." Choose from the "listings" Display Settings, next click on the Identify Monitor [button]. You need to select the (Number 2 Monitor), this will identify any other device connected to the computer. Acknowledge the device connected to the #2 Monitor; is it the TV? If so, give a try, and hope the solution helped, if so take the time to give a "Helpful Rating, I appreciated it, thanks!
May 16, 2010 | Toshiba Tecra A3 Notebook
I have a Toshiba 50hp66 that the power light cycles from red to green with a simultaneous clicking of a relay on the power board. I check for power at a few points per the Toshiba service manual and iy is...
Check the fuses on the ysus & zsus boards. Are any fuses on boards open . Disconect power cabels to ysus board first {board on left} . put tv on . if the light is green the ysus board must be replaced.
Mar 28, 2010 | Toshiba TheaterWide 50HP16 50 in. Plasma...
Toshiba satellite A85-s107 dvd/cd drive has quit working
you should try this start-my computer-right click-manage-device manager -dvd/cd drives-here right click uninstal or update driver.
this should work is your drive in not damage.
Jan 29, 2010 | Toshiba Satellite A85-S107 Notebook
Driver toshiba satellite SA 1870 160c/4
Thank you for contacting the experts. I have the drivers you requested listed below. I trust this was helpful and thank you for contacting the experts.
http://www.drivershq.com/Drivers/Toshiba/Satellite/U205/4183/9941/24866/Drivers.aspx
Jan 18, 2010 | Toshiba Satellite U205 Notebook
Drivers for TOSHIBA tecra m2 ptm20u
Hi!
You can donwload free drivers from the following link---
Drivers for TOSHIBA Tecra m2 ptm20u
Please do rate this solution as FixYa and revert for further assistance.
Thanks
Rylee
Jun 20, 2009 | Toshiba Tecra M2-S730 Notebook
Same Video garbage on screen and external monitor
On a laptop, the video card is part of the mainboard, not cost efectively replaceable. If there is video garbage on the screen, looks like a new computer unless you want to disassemble it to see if there is a loose connection between the display and the mainboard.
Jun 11, 2009 | Toshiba Qosmio G35-AV650 Notebook
Toshiba Satellite A45-S250 cooling fan not working
I would suggest you take the laptop apart and inspect the fan, if its covered in dust, it might be unable to rotate.
yes this is a fairly easy repair and can be done at home. You will need to find a replacement fan for it though, look at the numbers from the old fan.
Let me know if you need anything else.
Thanks,
Ekse
Feb 16, 2009 | Toshiba Satellite A45-S250 Notebook
How do I install a DC-IN harness on my laptop: toshiba satellite r15-s822
you actually have to take the bottom of the laptop apart theres alot of screws. once you take it off just unplug the dc adapter and attach the new one i just did it my self.
Jun 20, 2008 | Toshiba Satellite R15-S822 Tablet PC
Faulty ex wife and my computer
Well before I could actually even get further or deeper into the fix on my laptop the ex-wife had a compromise for me. Needless to say after a quite involved bickering and bartering sesion, the end result is she is now the proud owner of this Toshiba laptop. I appreciate the fact that there is a resource like this to aid in repairs of this nature. Thanks for your time...J
Apr 05, 2008 | Toshiba Satellite A105 Notebook
Toshiba Satellite A75-S231 Notebook Logo
50 people viewed this question
Top Toshiba Computers & Internet Experts
Ekse
Alun Cox
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
