I have the same problem and removing the power cable did not help. Nor did anything else I have tried (opening and closing output tray, input areas, etc.). Even removing the power cable for a day didn't fix the problem.
AnonymousMar 13, 2014
I was printing and my printer caught a paper jam .. idk how to fix the paper jam and its hard to take outI was printing and my printer caught a paper jam .. idk how to fix the paper jam and its hard to take out
AnonymousMar 15, 2014
No jammed paper, no reasonNo jammed paper, no reason
You can't post conmments that contain an email address.
PLEASE REMOVE THE POWER CABLE AND REINSERT IT IT SHOUL BE OK AND IF STILL PERSIST JUST RESTART THE PC IF STILL RESIST PLEASE LET SOME TECHNICIAN TO CHECK FOR THE SENSOR FOR THE PAPER JAM ...
GOOD LUCK
SOMETHING MOST LIKELY FELL DOWN IN BACK PAPER PATH OR TORN PAPER THAT HAS PAPER SENSOR STUCK. HARD TO SEE SOMETIMES. MIGHT WHAT TO TURN MACH UPSIDE DOWN AND SHAKE BE VERY CAREFULL
Try this...With te printer off line, press the paper feed button making sure thre is paper in both feed trays. Once it print, a blank page go in and change back t your desired papper source. Hope that helps, please let me know.
The 6A00 is a Canon generic code for paper path jam.
Solution 1: Move the printhead carriage back and forth a few times.
Solution 2: Check the purge unit: Moving the print head assembly will not clear a purge unit if its jammed with paper, paper clips, push pins, screws, cookie crisp, flower bud pods or the like.
Solution 3: Press the ink pads down in the purge unit.
canon i960 -three flashing orange lights (paper jam error) but no paper is jammed. The print cartridge will not slide to center either-- I have tried to get the printer into service mode, but cannot get there because the orange lights never stop flashing.
