Can you please scan and forward to my e-mail address [email protected].
I thank you very much, misplaced manual during move, and now I cannot record.
Happy New Year
Gina
SOURCE: Need manual for SANSUI VRDVD4005
You can get the manual on the link below.
http://www.managemylife.com/mmh/owner_manuals/26967/SANSUI-DVD-VCR-Combo-L0311311?brand_name_search=VRDVD4005
Good Luck
SOURCE: vcr to dvd recording
As i recall, +r's will only format in dvd vr, the unit does not like high speed recording disks. switch to dvd drive - insert blank disk - if no format screen - goto (on remote) setup - onscreen menu - system setup - disc setup - new disk format - hit center button in ring on remote to change to vr or move up to reformat as vr. once disk is formatted, use record speed button on remote to set record speed 1,2,4,6 hr then switch to tape deck with tape in and stopped at begining, on remote hit dubbing, it will ask you confirm dubbing vhs-dvd .... toggle over to yes & hit center button... away you should go... c245 is a copyguarded tape.
SOURCE: setting the clock
Use an Aiwa Hifi Remote Control...Turn on the L300 (without any DVD on the player). Wait until in the TV appears "No Disc" Open the tray and put a DVD from other region (not zone 1), don't close the tray!!!. On the remote control of the Aiwa press the "Clock" button, in some remote control you must do a button combination like "Shift+9" (Is the combination to see the clock, do the combination fast), and in other model of Aiwa remote control doesn't appear the clock button, you must try with the "random" button. If you do it right, in the corner of TV where "No Disc" appears it will say "adjust complete".
SOURCE: Sansui DVD Vcr combo wont play Dvd's model no. VrdVD4005
either the lens is weak in your dvd player or the get your cd checked in another dvd player to confirm the doubt.what exactly has problem.the player or the disk. thanks.
you will need to run a cleaning disk in it , if that won't work then it will have to be taken apart to clean the laser eye manually
which then if you can't do this then you will need to take it to a local repair shop where they can do it
electech
