I'm having 2 GB micro sd memory card for my mobile nokia 5310expressmusic ..... and it is password protected ... bit actually i have forgotton the password and now i'm using another phone ... in other phone the memory card is not openinng its asking for password .... i have tried also by connecting the data cable but in nokia pc suite its showing that there is no memory card ...., i had also tried thru card reader's but its not opening ./... is there any solution to unlock this card without losing the data in memory card ... plz help me out ........
SOURCE: Unlock 1 GB micro sd memory card of Kingston
HI, all you need to do is to get a usb box and good flash file, insert the memory card in th usbox then flash it.
Engineer Raphael.
SOURCE: micro sd unlock (6300)
You must put your card into mobile with symbian operating system and then formate it there, your card will be like new!
SOURCE: i'm having 2 GB micro
Nope the cards are encrypted if you cant remeber the password your data is lost. or get a hold of the old phone that has the password stored and transfer the data off the card via the usb cable.
SOURCE: unlock 1 GB micro sd memory card of Kingston Made
i got this problem before, but i don't know if its work for you.
i got this problem and i reformat the memory card on desktop.
right click on the drive and click on format...
No, there is no other solution other than formatting the memory card. That is why passwords are dangerous friends. It should always be such that you can remember it without writing it down anywhere and not forget it.
I GOT SAME PROBLEM MY MEMORY CARD IS LOCKED WHT THE PASSWORD
