Chances are you've blown the output transistors. Speakon connectors cannot short out but jack connectors can and if it was not inserted properly you'll have presented a dead short to your powered mixer. In any event it is really bad idea to connect anything when it's switched on. If you're really lucky replacing the output stage (which will probably be dead short on the transistors) and re-adjusting the bias should sort you out.
SOURCE: Behringer PMP5000. The Powered Output B dead
Make sure the three position slide switch is set correctly for the stereo usage, that is NOT the bridged OR the Mon mode.
MAKE SURE the pan pots are set to middle as they control the spit of the audio to the two channels.
This is a class "D" amplifier (switching) and there really isn't any fuse for a single channel.
MAKE SURE your speakon connections are good by swapping your speaker cables.
I repaired my unit and had to do that without schematics... Behringer will not give them out. Mine had a severe arc-over on one side power amp taking out about ten transistors and diodes and one swithcing regulator chip. Had to cut out the "cancer" of the burned board.
This unit uses a complementary output stage that is made up of one transistor on one side and a pair in parallel on the other. This drives the inductor/capacitor filter... I think the switching frequency is between 100KHz and 1 MHz as I recall. All those transistors were gonzo. It also fried the main power switching transistors in the power supply, several smaller transistors, diodes, and the switching regulator chip.
Also two 10 ohm power resistors were fried. They soft start this unit by charging the main caps via two resistors that limit the inrush current.
A small switching supply has to come up first before the main supply which sends the DC to the amp section.
SOURCE: Need Behringer Eurorack mixer power supply connector
Those were used for mic connectors at one time,,, they are related to the Amp 91-MC3F family of connectors and those are out of production and they are demanding $20 to $50 for one connector.
That is a ridiculous price and I would be tempted to swap out the connector for a more available design.
On eBay item 250401122616 is one but they want $13 pus $11 shipping which is a rip off.
These were used on some OLD CD radio mics.
SOURCE: Behringer XENYX 1622FX, won't power on. Phantom power works(?)
After reviewing the schematic, I don't understand how the Phantom power can REMAIN on with the power switch off... this CANNOT occur except for what energy is left in the 48 volt supply filter cap... This might last for minutes after the fuse went... UNLESS you have devices connected which are backfeeding the 48 volts. (which would be a disaster)
The 48 volts, +/- 12 volts and +/- 15 volts and the +5 volts ALL come from the SAME switching power supply. I suspect one of the filter caps went or the primary switching regulator a TDP245Y chip.
You should ONLY work on the line side of this using an ISOLATION transformer since the line side has lethal voltages.
To do testing, one replaces the fuse and puts a 60 Watt light bulb in series with the hot side of the inout line. The lamp "acts" as a resetable fuse and limits the current for testing. When all is well again, the lamp will remain out with the power flowing through it.
The D1 diode bridge and C7 input rectifier and filter are first things to check. You can do those with an ohmmeter.
I will caution you to ALWAYS power any and all equipment from the SAME power source. Plugging in devices from across the room will set up ground loops and any ground fault will fry equipment.
SOURCE: Hello; I have a used Behringer pmp5000 mixer. The
Without knowing how you have your monitors configured it is hard to analyze what you have posted.
In brief, SW3 on the schematic that selects MAIN L and MAIN R in the upper position, MAIN and MONITOR in the middle, and bridged in the lower is used to configure the internal amps.
In the upper position, the amp power outputs come from the mixed stereo bus and are simultaneously controlled as a stereo signal by the MAIN slider.
In the middle position MAIN and MONITOR, the left amp receives the signal from the mix bus and is controlled by the MAIN slider. The MONITOR output from the other side of the power amp is controlled ONLY by possibly the "MONO" slider.
The schematics are hard to decode and what is needed is a signal flow diagram.
For my uses, I don't try to use splitting the power amps between mains and monitor but prefer to use the mains together with SW3 in the upper position (Note your 27 may be refering to the user manual designation for same switch). I then use another small amp from the 1/4 inch MONITOR jacks whcih are under control of the MONITOR sliders.
Please note that the MIX for these two MONITOR channels is controlled by the MON1 and MON2 knobs for each channel.
SOURCE: Behringer XENYX 2442FX Mixer. The power light
You have likely lost one, probably the +15 volt power supply... This is possibly a shorted component or a short on the circuit board causing this. It takes some skills at troubleshooting to find this. Sometimes using a thermal imaging camera will show hot spot... other times you have to search with a millivoltmeter. The rude solo light is driven by an op amp that uses both polarities of 15 volts and to turn it on it pulls negative... Hence I suspect the +15 is missing.
