Maytag Neptune FAV6800AW Top Load Washer Logo
Anonymous Posted on Nov 03, 2012
Loud noise how to locate shipping pin and how to remove it when i find it?
  • Anonymous Nov 03, 2012
    how long will it take to get my answer
Richard Roth
Level 3:
Top Expert:
  • Maytag Master 9,472 Answers
  • Posted on Nov 04, 2012
Richard Roth
Maytag Master
Level 3:
Top Expert:
Answers
9472
Questions
Helped
2626589
Points
28464
I don't believe there are any shipping bolts on that unit.
Loud noise during spin cycle now they are stacked
a loud noise comes when you forget to remove shipping bolts after installation or if the shocks are worn out it makes noise thirdly the bearings might be worn out if the washer is more than 6years old
I have a new top loader GE washer. it works fins but when it comes to drying, it shakes like crazy and makes very bad hammering noise
Make sure the washer is level. Most important make sure the shipping pins are removed. Classic! Good luck! The pins are located underneath your washer. Tilt up and pullem out!
1helpful
Suspension plate
The suspension plate should be loose and float between the frame and base. The pin you saw was a shipping pin, they usually are caught in a little plastic cup attached to the base but sometimes fall to the floor, this is normal too. The tub being loose is normal for the top, it is held down by the springs below the tub but nothing on top. By a loud noise, what kind of noise is it? If it is a very loud ratcheting noise when it slows down then the basket drive(spin tube) and block need to be replaced. If it is a growling noise then that is pump and may be normal if the basket is not spinning. If this is the case look very close for an article of clothing caught between the tub and basket.
Front loading kenmore 86983110 makes loud noise when turned on. Think that there is a problem with the belt. I am tryng to take it apart now and do not know how to find the belt
The belt is located at the back of the appliance.
To remove belt you have to remove a panel at the back, on some model you remove top panel first.
The belt does not make loud noise. Loud noise when spinning is usually caused by bad drum bearing, located at the back of the drum.
Regards.
2helpful
My new Ge washer is making loud and vibrating noises while spinning. the washer does not seem to be off balance.
Who installed this? Sounds like they didnt remove the shipping rod located on back of machine. If so, refer to instruction manual for how to remove rod. Usually just pulls out.
2helpful
Washer loud grinding noise spin stop
if its brand new it shouldnt be making a loud grinding noise id get it checked make sure they removed all shipping bolts
Squeaking Washer
did you remove the shipping pins pins when you installed it
2helpful
4answers
Spin Cycle
Remove the bottom panel, it is held on by two screws, and make sure the foam block and shipping brackets are removed. My installer left them in.
Top Maytag Washing Machines Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
ZJ Limited
ZJ Limited
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
