AR 5618 F2-64 ERROR CODE PROBLEM PLEASE SOLVE
Sharp ar-5618 in f2 to 2f error
My machine model AR5618s
error code 2 and F than 64
what solution?
Https://printcopy.info/?l=en&mod=erc&brand=Sharp&model=AR5618&code=F2%2064
Replace toner cartridge, and then if necessary, replace developing unit.
http://www.copytechnet.com/forums/sharp/91276-f2-64-a.html
Additional cleaning steps described at the internet link above, and other possible parts to be replace if necessary..
SOURCE: My Sharp Ar 5316 is showing F2 or 2F Error what will i do
My Sharp Ar 5316 is showing F2 or 2F Error what...
SOURCE: Sharp ar-163 model Error code F1
You can hold down the start key when the F1 is displayed it will show a sub code. The service manual for that model shows only one F1 code which is an F1-06. That is a shifter motor trouble. That is the section after the exit that offsets the copies.
You can reset the code with the instructions below. If the error recurrs then chech the exit section shidter for proper movement. You may require an on site technician to remedy this issue.
To reset the error code:
Hit <clear> <interrupt> <0> <interrupt>
14 <start>
SOURCE: i have a sharp photocopier AR-5316 flashing error
i have a sharp photocopier AR-5316 flashing error code is E7 how to reset this code and solve the problem
SOURCE: H2 error
An H2 is an indicator that the temperature sensing device is reading open, preventing the machine to warm up. There is only one way to correct this and that is to replace the thermistor, and that takes a technician. Not a hard job but a novice could get into trouble and make matters worse. Aloha, Bill Monroe
SOURCE: sharp AR-R550n
Hello sir; You may try to perform a reset procedure as follow;
press " program", " * ", " clear ", " * " and start key, then enter 17, press start again, turn machine off and back on.
f2 64 dk solusan chahiye meri mashin 3000 copi par f2 64 coad dati hai
sharp machin me f2-70 aa raha hai
new machin
what happen this machin
how can solve this problem please tell me
sharp AR5618 error F2-64 how to rectifier this error
What's the 5618 code for restart
