If their is a sound with totally black screen the cause would be either inverter board get bad or the screen back light was damaged. if just a white screen, you can noticed by looking at the dark room. then the cause would be bad t-con board. just let me know if it can help you can ask further solution thanks for consulting through fixya.
SOURCE: Polaroid TLX-04244B Remote wont work
5 Digit code is 15231
3 Digit code is 494
Hope that helps, took me about 4 hours to get that figured out!
SOURCE: screw size needed
I strongly advise and recommend you get the details and if possible the screws from the shop you got it from.
This advise is enssential so as to get the best from the certified sales representative
SOURCE: I have a polaroid TLX-04244B
Failed capacitors are common problem in ALL switching power supply in TV and monitor. You may also want to look for cold solder joints and loose connections.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx
SOURCE: Polaroid tv model#TLX-04244B....No pic,no sound,blue
Part for this TV are not cheap and not easy to get as you can see here: Basic LCD monitor and TV troubleshooting guide: Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
http://www.shopjimmy.com/catalogsearch/result/?q=polaroid+TLX-04244B
You will need to do some in-depth troubleshooting to find which board/s are bad.
Power supply module will be the first place to start.
So please read my guide first.
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
SOURCE: i have a poaroid TLX-04244B flat screen tv but no
check out polaroid tv parts its a website. just google polaroid tv parts and it should be simple to find a remote. also a universal remote would work well that can be purchased at any local best buy, etc...
