HP PL5060N 50 in. Plasma HDTV Logo
Doyle Smith Posted on Nov 04, 2012
Hdmi sound unavailable - HP PL5060N 50 in. Plasma HDTV
Anonymous
Level 1:
Problem Solver:
  • Contributor 7 Answers
  • Posted on Dec 11, 2012
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
7
Questions
0
Helped
2851
Points
7
I had this problem for weeks before giving up. I just had another go and i resolved this by downloading my gpu driver but not installing, then i un-installed my mobo hd sound driver and my gpu hd sound driver. Then i installed the latest nvidia driver from my hard drive. When the driver activated i got some buzzing for 10 secs and then presto (hd sound) via HDMI. However my pc tells me still "no audio capable display". computers are often wrong.
2answers
How can I get broken HDMI card repaired?
They are too expensive to repair. Purchase a new one from the Manufacturer or replace the entire. unit if it is unavailable or too expensive.
How can you get netflex with apple tv
Simple.
Connect apple TV to TV via HDMI port. Turn apple TV on and go to Netflix app. Sign up or enter existing Netflix account info. You should be set.
*if Netflix states unavailable try again later. I plug apple TV for 30 seconds and try again.
Unable to adjust the tint
I think your TV may not have this option at all. However, I can also come up with other ideas:
Some adjustments might become unavailable depending on the input or content, have you tried adjusting this parameter in different inputs? e.g. TV channels, HDMI, composite, component? Or different content? e.g. HDMI input but with a signal from a bluray player playing a bluray disc vs. signal from a bluray player playing a DVD. If you don't see the tint "unlocked" in any of these different scenarios the option might as well be natively unavailable.
I have a 60" Mitsibishi TV and I am trying to
When your notebook computer is connected to an HDMI device, you may encounter certain display and sound issues. For example, if you have your notebook computer connected to an LCD TV and/or surround sound speakers with a high-definition multimedia interface (HDMI) cable as part of a home theater system, you may encounter some common HDMI display and/or sound issues such as the following: If you are experiencing one of the following issues, click the link to go directly to a section of this document for a resolution. If you are experiencing an HDMI display or sound issue that is not listed above, please contact HP for assistance. Set HDMI sound output c02654744.gif Make sure that HDMI device is enabled and selected. To make it the default sound playback device, select ATI HDMI Output and then select Properties . The HDMI cable must be connected when it is configured. Use correct HDMI cable for your HDMI device There are three types of HDMI: 19-pin (normal head), 19-pin (small head), and 29-pin. If your computer and HDMI device use different cable types, adapters are available. For more information, see HP Notebook PCs - Overview of HDMI and DVI Connections for PCs . Content protected error message If you are playing an HD DVD on your notebook computer while it is connected to an LCD TV with an HDMI cable, you may see an error message that reads, The content is protected. The content is not allowed to be played in current mode. This error sometimes occurs when single mode settings are selected. To resolve the issue, click to accept the message when prompted, and the movie will play. images do not display properly When the notebook computer is in HDMI mode, images sometimes are distorted or do not display at all. To resolve this issue, use the HP Support Assistant to test your computer and install any updated drivers. Alternately, download and install the latest NVIDIA GeForce driver from your model from the HP Software & Driver downloads page . For more information about downloading and installing drivers for your HP notebook computer, please see the Locating HP Software, Drivers, and BIOS Updates in Vista support document. Surround sound option is unavailable First, confirm that your notebook recognizes HDMI audio by right-clicking the Volume icon in the Windows system tray and selecting Playback Devices . If you do not see HDMI Output then you may need to reinstall or update your audio drivers. Also, make sure your notebook's BIOS is up-to-date. When using WinDVD to play a movie after selecting HDMI as the default audio output, the surround sound option may be unavailable. To resolve this issue, please update to WinDVD version 9.0 or later at the HP Software & Driver downloads page . If you are using the MediaSmart program, make sure you are using the latest version. For more information about downloading and installing software updates for your HP notebook computer, please see the Locating HP Software, Drivers, and BIOS Updates in Vista support document.
I have a Sharp LC-42D62U and have our DVR from cable connected to HDMI #4. I want to hook up a Roku via HDMI to HDMI #5 but the input source shows unavailable sign. Is there a way to get both HDMI...
If your Tv has this many HDMI ports it will have a menu to access each one separate. Go to your Tv's settings menu and look for your HDMI ports to use.
3helpful
My hdmi port is not working
I have Verizon Fios and there's a known issue with the motorola HD boxes that they have bad hdmi ports, the screen goes green and that's it, nothing I can do about it I just use component cables. You need to be sure it's your tv not the cable box. Try the hdmi on a dvd player or ps3 or whatever else you have first just to be sure it's the tv at fault not the cable box. If you determine it is the tv you need to replace either the main board or the video board depending on your specific tv model. Some have the video inputs on the main boards some have video boards.
I WANT TO SET UP HDMI FROM LG RECORDER TO SAMSUNG PS42C91HD PLASM
I think if you look in the instruction manual under faults,it say the cable must be a certain value ie 1.3,it should tell you on the package.I hope this is of some help
I have hd picture but no sound, tv says hdmi audio unavailable
I called Verizon and exchanged my STB from a QIP 6416 to a QIP 7216 and it solved the HDMI audio problem. This looks like the fix.
3answers
Lc-42d62u 42in.
This is a common issue with HDMI. Try unplugging the TV for 2 monutes and also reset the cable box as well by inplugging.
Top HP Televison & Video Experts
 Mikey
Mikey
Stan Ford
Are you a HP Televison and Video Expert? Answer questions, earn points and help others
