I have the same problem on my ASUS vw190. everybody is talking about capacitors poped. 2 solutions are posted, firstly replacing the capacitors is best, secondly reducing the brightness to 50% solved the problem for me. screen still fluctuates. going to have a look inside. i will be back with more feedback.
SOURCE: sceptre LCD - no display
There is 2 caps in the power supply that are blown I have fixed 15 of these LCD with the same problem.
SOURCE: Sceptre X9G Komodo IV
I have a 19" Sceptre Comodo display. After 3 years it got the problem everybody complains about. Took it apart yesterday.
There are 4 capacitors in a row on the power supply board (it has a socket for the power cord and is covered by a metal shield. The caps are barrel-like things standing upright on the side opposite to the power cord socket.) Two of them are 470 uFx 25 V, they are next to each other. In my case, one of them popped up and another one was bloated. I pulled out the power supply board (make sure you unplug the power cord and press the power button do discharge the high voltage caps before messing with your monitor) after disconnecting all sockets (mark'em!). I assume that you have new caps handy (I paid $2.10 for a pair at a local electronics store), they must have the same capacity and voltage rating. Now grab a soldering iron, remove old caps, and put new ones in. You must observe polarity! (Usually "minus" pin is labeled on the cap's side. Mark down "minus" and "plus" pins location of old caps and put the new caps in exactly the same way! Otherwise, you can blow the caps.) If you are not used to work with a soldering iron, hire somebody or buy a new monitor. Check the quality of the work (no shorts, solid contacts, etc), assemble the monitor back and may be it will work (did for me). If it does, you put one monitor less into the city dumpster, be proud to get a working monitor for less than $5, and force you mother-in-law to take this shiny new replacement display she just bought back to the store.
Of course I do not guarantee that my procedure will work for and you can use it at your own risk only (i.e. I am not liable for any damages).
SOURCE: monitor goes black 1 second after coming to full screen
Same problem here. Does anybody have an answer?
SOURCE: blinking monitor power button and flashing image
I buy and sell these monitors (Dell E17FP) the problem is with the transisters (Q739, Q740, Q759, Q760) they short out and the monitor will just blink on and off. You have to desolder them and test them with a simple battery and light circuit. The reason they blow is because of the dirty solder joints by the transformers. If only on pair of backlights work the problem maybe transisters Q751, Q743. I home this answers your questions.
SOURCE: When I press the power button LG displaying chars for 1 second
Had the same problem, turned out it was due to a faulty capacitor on the inverter board, 680uF 25V (105 celsius rated). Simple to fix once you have the unit dismantled and the correct replacement part. Two screws hold the shroud on, but you need to be careful with an (old) credit card levering it off.
Unit is now working fine.
