Homelite LR 4300 generator only supplying 230v, even at the 120 outlets
Engine runs normally, about 3600 rpm; did not have any previous issues. I metered the power output after I smoked my furnace aquastat when I engaged the transfer switch. I then checked the kitchen convenience outlets and they were 230v. Went to the generator and checked output at the outlet and it was also 230v.
It be better to obtain an unit that already design for your area as it will the appropriate electrical outlets.
As for the 30552-00 would be 60 Hz with running at a governed speed of 3600 (3750 unloaded).
Being a two pole generator frequency is determined by dividing engine as follows. 3600 / 60=60. Engine is RPM is in minutes and must converted to seconds. For 50Hz operation the engine speed must be reduce to 3000 rpm (50hz * 60seconds = 3000 rpm)
You cannot, speed is propertional to voltage on these, as they have capacitor voltage regulation. Do not use this for powering home appliances, it is common to see this design and not a problem. If you add load and it will decrease but so will the frequency
Not sure what you mean "high voltage rpm power generator out", however many people have asked how to adjust the engine for proper voltage output. On generators with~out a voltage regulator, I adjust the engine RPM by using a digital voltage meter that has a Hz setting. Adjust the governor untill the meter displays 60 Hz. With the geneator producing 60 cycles, I know that the engine is turning 3600 rpm (the engine produces max hp when it is turning 3600 rpm). At this point, read the voltage output to verify that the range is between 115 ~ 120. On generators with a voltage regulator, verify/adjust that generator is producing 60 cycles then adjust voltage by turning screw at the regulator (some regulators are sealed with potting compound and can not be adjusted). If your power demands are not that great and you appliance can operate at 50 cycles, adjust governor as needed. Lowering to 50 cycles will also reduce output voltage. Good luck
Most low voltage conditions on generators are simply due to a low engine rpm. Most modern generators are 2- pole windings. So your engine rpm should theoretically run @ 3600 rpm. which will produce 120/240 volts @ 60 HZ. In actuality You want to set your rpm's @ Approx. 3720rpm no load. About 62.5 Hz. Without getting to technical this will give you your desired 120/240 volts loaded. Hope this helps.
check your volt-meter..if it works...then find out if 3600rpm is normal for that kind of generators...if so...check AVR card...its allways the problem...replace it
i hope i helped...send me an email for more details
I worked at a tool rental center while going to college and learned how to service generators. Most appliances/tools require 50 to 60 cycles at 110 to 120 v. Your engine was designed to give maximum horsepower at 3600 rpm. Adjust the engine speed to produce 60 cycles and the engine should be at 3600 rpm and producing around 120v max. (Some special generators were designed to produce 230v 180 cycles, check manual) If your generator incorporates capacitors check them for at least 95% of printed uf value. They should be removed from circuit for testing. If there are two caps and one is weak make sure the new cap reads close to value of remaining cap. Finally there is usually a voltage regulator that varies the power to the armature magnet trying to maintain steady voltage depending on amp draw and engine condition. This regulator has no adjustment and is pass or fail type of item. Good luck, enjoy
Most generators use a flyball type governor within the engine to control rpm; also there is a voltage regulator that tries to maintain voltage at about 115v. The voltage regulator varies the voltage to the armature increasing /adjusting magnetic force. Use a meter with htz or freq setting to adjust engine governor to 60 cycles. When the generator is producing 60 cycles, the engine should be turning 3600 rpm, max power range. At 3600 rpm the voltage should be 115 to 120 volts. Loading the generator will cause governor to try to maintain 3600 rpm. Check engine manual for proper adjustment of gonvernor and linkage. The governor mech should last the life of the engine, however governor system does wear out. Expensive repair. enjoy
