Question about Kyocera Mita KYOCERA/MITA - KM-C3130 Printer
Hi! I've got a KM 1650 it boots up then it say ready to copy after few second now printing then C400 error occur please help. kyocera KM 1650 error now printing then c4000 error comes up
Hi! I've got a KM 1650 it boots up then it say ready to copy after few second now printing then C4000 error occur please help. kyocera KM 1650 error now printing then c4000 error comes up
  • Kashif Ces
    Kashif Ces Feb 27, 2013
    lcu unit problem
    New Friend:
  • 21 Answers
C4000 polygon motor sychronize error, try to cleaning polygon, if not effective, need to replace new polygon.
Posted on Nov 05, 2012
Testimonial: "thanks it help alot"
  • 1 more comment
  • Charlton Nov 05, 2012
    Hi! Cesario Cabahug do i only clean those mirrors
  • Charlton Nov 06, 2012
    Thanks, I find that LSU has been removed how stupid of me for not Checking
  • Charlton Nov 22, 2012
    I have a C-0211 error on Bizhub C450, I did replace lift up motor and tray2 board (PWB -Z), I did try a few other things no joy for me. Can anybody please assist
6ya staff
SOURCE:
How do I clear A-4200 on a Kyocera copier KM 2016
A C4200 IS A BAD LASER UNIT , EXPENSIVE REPAIR FOR A COPIER THAT OLD.
May 21, 2015 | Kyocera Mita Drum Cleaning Blade Km 1620...
How to solve error c4000 for Kyocera KM-2035 copier? it has stopped
c4000
The Problem:
inside the laser unit Polygon motor synchronization problem
The polygon motor does not reach the
stable speed within 15 s of the START
signal turning on
Causes:
1-Poor contact in the
polygon motor connector
terminals.
Reinsert the connector. Also check for continuity
within the connector cable. If none,
remedy or replace the cable
2-Defective polygon
motor.
Replace the polygon moter or LSU.
May 29, 2014 | Kyocera KM-1505 Copier
How do I solve Kyocera KM-1650 error code C6400
Usually these are just software issues which can be solved by uninstalling the old one and reinstalling it. Cleaning the system with a cleaning utility of all old unwanted files, links etc may help solve the issue. Restoring your system to an earlier date when you didnot have any issues will also solve the problem. Especially in Windows Xp.
May 12, 2014 | Kyocera Mita KM-1650 All-In-One Printer
Black lines on copy only when printing but copying is ok i.e km 1650
If this only occurs when using the document feeder then you will need to clean the smaller glass that sits next to the large glass that you manualy place your documents. The document feeder scans the originals over the small glass and any ink ,whiteout that may be on the glass will appear as lines down the pages
Oct 24, 2013 | Kyocera Mita Office Equipment & Supplies
How do I install driver for Kyocera CS 5035 on MAC
Kyocera and Copystar models are the same just replace KM with CS.
The following instructions should help you. TO download the current driver use this link to th emanufacture website; http://usa.kyoceramita.com/americas/jsp/Kyocera/resource_details.jsp?rid=18657.
Kyocera Printer Drivers and Mac OS® X 10.5 Leopard FAQ:
Is the installation for Mac OS X 10.5 the same as for Mac OS X 10.4 and earlier? Mac OS X 10.5 introduced a new printing architecture that requires changes to the installer and installation process. For this reason, Mac OS X 10.5 requires a new printer driver installer.
I cannot see my Kyocera AppleTalk® printer. How can I make it visible to OS X 10.5? AppleTalk is disabled by default in Mac OS X 10.5. Enable AppleTalk to discover your Kyocera printer.If you use the Kyocera installer, a message will appear, asking you to enable AppleTalk. Click Yes to continue the installation.
I cannot find Printer Setup Utility on Mac OS X 10.5. Is it still supported? Apple has removed Printer Setup Utility from Mac OS X 10.5. To install a printer, open System Preferences and click Print & Fax.
When I manually install a printer, multiple PPD files are listed for the same Kyocera model. Which should I choose? When manually installing a printer or changing a PPD for a installed printer, both Linux and Mac OS X PPDs are listed for some older Kyocera models due to a change in PPD handling in Mac OS X 10.5. Linux PPDs can be identified by the word Gutenprint in the PPD filenames.
Supported Multifunction Printers: KM-1650, KM-1815, KM-1820, KM-2050 ,KM-2530 ,KM-2550, KM-3035, KM-3050, KM-3530, KM-4030, KM-4035, KM-4050, KM-4530, KM-5035, KM-5050, KM-5530, KM-6030, KM-6330, KM-7530, KM-8030, KM-C830, KM-C830D, KM-C850, KM-C850D, KM-C2520, KMC2525E, KM-C2630, KM-C3225, KM-C3225E, KM-C3232, KM-C3232E, KM-C4008, KM-C4035E, CS-1650, CS-1815, CS-1820, CS-2050,CS-C2525E, CS-2550, CS-6030, or newer. Supported Printers: FS-820, FS-920, FS-1018MFP, FS-1020D, FS-1030, FS-1100, FS-1118MFP, FS-1300D, FS-1800, FS-1800+, FS-1900, FS-1920, FS-3800, FS-3820N, FS-3830N, FS-6020, FS-6026, FS-9100DN, FS-9120DN, FS-9500DN, FS-9520DN, FS-C5016N, FS-C5020N, FS-C5030N, FS-C8008N, FS-C8026N, FS-C8100DN, or newer.
I hope this is helpful,
Shawn
Mar 08, 2011 | Kyocera Copystar CS-5035 Copier
C-4 is showing up on our photocopier, a Kyocera KM 1620???
A cover open state is detected during copying or printing .... please switch off the printer and switch on the printer and check it .......
Dec 04, 2009 | Kyocera Mita KM-1650 All-In-One Printer
Please Help Kyocera KM-1510 Grayscale Copier & Minolta D251 C0F32
check the exp.lamp . it mzay be blinking at the time of scanning the original.
Feb 17, 2009 | Kyocera KM-1510 Copier
I have kyocera km 1650 and i want to resert the fuse error C6400, how cqn i do it?
press status key
scroll down to service
press enter
press 163
press enter
wait 10 seconds
recycle power
Jan 26, 2009 | Kyocera Mita KM-2050 Printer
Kyocera Mita KYOCERA/MITA - KM-C3130 Printer Logo
686 people viewed this question
Top Kyocera Mita Office Equipment & Supplies Experts
Adorjani Laszlo
AAAA262430
Marvin
Marvin
Are you a Kyocera Mita Office Equipment and Supply Expert? Answer questions, earn points and help others
