Question about Makita Hammering
What grease do you use for a makita demolition hammer
Alternative grease
  • Makita Master
  • 2,015 Answers
MAKITA HAMMER DRILL GREASE 30G (181490-7) or for the older HM models Hammer grease Makita P-08361
Posted on Mar 16, 2016
Anonymous
SOURCE:
jmgldsmth
Jim Goldsmith
  • 2005 Answers
SOURCE: Need manual for Hitachi Demolition Hammer
http://www.hitachipowertools.com/product/files/concrete_masonry/demolition_hammer/H65_OM.pdf
Posted on May 28, 2009
darjr
Darial Jr Lasaria
  • 379 Answers
SOURCE: Makita demolition hammer stopped working - believed electrical pblm
you have to use an ohmmeter to check it, you must check the continuity of motor coil after the switch terminal if in this point you have the reading less than 200 ohms, try checking it before the switch but this time you have to switch it on. If you have the readings continue to check it from the Power Plug. Most cases the problem is only in Power cord .
Posted on Jun 01, 2009
Robert Sabino
  • 142 Answers
SOURCE: Bosch demolition hammer oozing grease/oil.
Look around there for some O rings we have had this same problem with some of our Bosch hammer drills, and they usually replace a set of seals around the nose of the tool
Posted on Jul 06, 2009
Editor925
Dean
  • 285 Answers
SOURCE: what type of oil i will luricate to my makita HM
demolition hammers require hydraulic oil in most cases.
Any good tool shop should have hydraulic oil to suit.
Posted on Feb 25, 2010
rowdy45176
David Ford
  • 2176 Answers
SOURCE: dewalt demolition hammer stopped hammering.
could be a few problems, the striker could be stuck from debris or the ram might be hydraulically locked. they make a rebuild kit for this tool if you are mechanically inclined. I would suggest first going to their site and downloading a parts breakdown and there you will find what is involved and the parts listing. It is "dewaltservicenet.com" and on the left hand side type in your model number and then follow the links to download this. Let me know if you need more assistance.
Posted on Apr 23, 2011
What type of oil shall be used in makita hm1304 demolition hammer?
You require Hammer Grease, All good tool shops should have grease to suit. see link below:-
Hammer Grease 90582 for Makita Power Tool eReplacement Parts
Feb 11, 2016 | Makita Hammering
What kind of oil grease goes in a. Hm1301 makita
A-90582 2 tubes of grease 30cc http://www.acetoolonline.com/Makita-Tools-A-90582-Hammer-Grease-30Cc-p/mak-a-90582.htm
Sep 11, 2014 | Hammering
What part grease to use for makita hm1500?
30 grams needed order nr its a grease with ordernumber 181490-7
And 193403-6 is the service kit for this machine.
Jul 02, 2014 | Makita Hm1500b 42-pound Demolition...
How do i chack bosch 60 lb jackhammer oil leval
Bosch hammer uses grease available in repair kit. Check ebay or parts house. Remove four hex bolts on the mid section of the hammer and pull off the lower end. Most of the grease goes here. There is a side cover to expose the drive gears if you hear gear noise. Depending on use, only needs grease once a year. Good luck.
Jun 30, 2014 | Makita HM1500B 42 Lb. Demolition Hammer
Type of oil use for demolition hammer
A old black graphite or yellow grease lubrication of the brand Makita
Apr 29, 2014 | Makita Hammering
What type of oil
http://www.homedepot.com/p/Makita-Hammer-Bit-Grease-194683-7/205182387
For outside chisels
Inside its depend on the model but most time its a Makita 181490-7 or for the older types Hammer grease Makita P-08361
Feb 19, 2014 | Makita Hammering
A friend of mine recently purchased a Makita HM1500B demo hammer. It came without grease. How much grease is required to initially fill the case? Is there a different type of grease that can be used?
If this was a new unit, it comes with the proper amount already in the gearcase. You might need some for the hammer bits (a small amount of lithium grease) but other than that until the tool needs repaired you should not have to add any.
May 09, 2011 | Makita HM1500B 42 Lb. Demolition Hammer
What type of oil i will luricate to my makita HM demolition breaker
Feb 25, 2010 | Makita Hm1500b 42-pound Demolition...
Hammering Logo
798 people viewed this question
Top Makita Hammering Experts
John Trevino
Pieter Vleeshouwers
Pieter Vleeshouwers
Andrew Taylor
Andrew Taylor
Are you a Makita Hammering Expert? Answer questions, earn points and help others
