If it does not spin see the following suggestions from Repairclinic:
It doesn't spin
If your washer won't spin, check these:
It doesn't pump or spinIt pumps, but doesn't spinIt spins only with the lid closed
If it doesn't pump water out or spin, check to see if the motor is running, then proceed as follows:
- If
the motor is running, your washer probably has a frozen pump pulley or
a broken pump belt. To check the pulley, remove the pump from the
washer and try to rotate the pulley manually. If it doesn't turn
freely--if it's frozen or stiff--replace it. If the pump belt is broken
or looks quite worn, replace it--but be sure to check the pump pulley
before you change the belt.
- If the motor isn't
running, the lid switch may be defective. If so, the washing machine
can't spin and may not function at all. The switch is inside the
washing machine main housing near the door frame. Often you have to
raise or open the top or front of the washing machine to get to the
switch. If it's defective, you need to replace it.
If your washer pumps out the water but doesn't spin, check these:
- The
lid switch may be defective. If it is, the washing machine doesn't
spin. The switch is inside the washing machine main housing near the
door frame. Often you have to raise or open the top or front of the
washing machine to get to the switch. If it's defective, you need to
replace it.
- The motor coupler may be broken. Many
Whirlpool®-manufactured washers use a small, relatively inexpensive
motor coupling. It's plastic and rubber and is mounted to the shaft of
the motor on one side, and to the transmission on the other. Over time,
the coupler wears out and fails. You may need to replace it.
- A
belt may be broken. Many washing machines have one or two belts. If a
belt is broken or badly worn, you need to replace it with a genuine
belt from the manufacturer. (Some washing machine belts are designed
with special characteristics not found in automotive belts.)
- The
clutch may be worn. If your washer is a GE, it may use a clutch to come
up to the proper spin speed. As the clutch wears out, it may prevent
the unit from spinning well or at all. If the clutch is worn, you need
to replace it. For this job, you probably want to hire a qualified
appliance repair technician.
- The drive motor may be
defective. Many washer brands use a reversing motor. For agitation the
motor runs in one direction, for spinning and draining, the other. It's
possible for a motor to burn out in one direction and continue to
operate in the other. If this happens, you need to replace the entire
motor.
- The transmission may not be shifting properly.
Older washers produced by Whirlpool® have a transmission with an
electro-mechanical shifter. If the shifter becomes even partially
defective, the unit may drain the water but not spin. This is a complex
system, if your washer has a shifter problem, you may want to hire a
qualified appliance repair technician to repair it.
- The
spin bearing or basket drive may be worn or seized. These components
allow the inner tub to spin freely inside the outer tub. When this is
the problem, you usually hear a loud sound during the spin cycle. Call
a qualified appliance repair technician.
On leaks:
It leaks
Your washer can develop several types of leaks. You can track down a leak based on when it occurs:
During fill onlyDuring drain and spin onlyAll the time
During fill only
If the washer leaks only during the fill cycle, check these:
- Air-gap
device -The air gap is a small device found on most washers that
prevents the wash water from being siphoned into the household water
supply. It's located either mid-way along or at the end of the black
rubber hose that comes from the water-inlet valve. Often it's made of
translucent plastic. If one of the air-gap components deforms or
cracks, you may need to replace it.
- The tube -There's a
rubber tube that runs between the water-inlet valve and either the
air-gap or the inlet spout. If it cracks or breaks, it can cause a
leak.
- Inlet spout -Most washers have a plastic spout
near the top of the main clothes tub that directs the water into the
tub. If the spout cracks or breaks free of its mounting, it can cause a
leak.
A
washer that leaks only during the spin cycle often has a leak in the
main drain hose. Inspect the entire hose and correct any problem you
find. Alternatively, the steel or plastic outer tubs can rust, split,
or be punctured. This may be most visible during large loads and high
water levels. If this happens, you may have to replace the entire outer
tub--but that may not be an economical repair to make. Consult a
qualified appliance repair technician for further details.
All the time
If the washer leaks all the time, check these:
- Hot
and cold water fill hoses - Check the hot and cold water hoses from the
household plumbing. If either hose is leaking, tighten it or replace
it, as appropriate.
- Main tub seal - The main tub seal
is located between the transmission and the outer tub. It's the primary
water seal in the outer tub for the transmission-shaft entry point. If
this seal leaks, you can see the leak by opening up the machine's main
access panel while the machine is full of water with a small amount of
detergent in it. The leak appears at the underside of the outer tub, at
or near the center. This seal is difficult to replace. You probably
should call a qualified appliance repair technician.
- Pump
- If the pump leaks, you can probably spot the leak when the tub is
full of water. The pump has two or more black rubber or plastic hoses
attached to it and usually has a drive belt that spins the pump. If the
pump is leaking, you need to replace it.
- Outer tub -
Over time, the steel or plastic outer tubs can rust, split, or be
punctured. If this happens, you may have to replace the entire outer
