"SMART Hard Disk Error"
"The SMART hard disk scan has detected an imminent failure"
It is normal to have SMART Hard Disk Error, regardless of the operating system you use. It is very clear from this error message that there is a hard drive or a solid state drive problem and that it will be dead in the near future. This can happen suddenly, but it will prevent the booting process. If this occurs, the user must take immediate action before crashing to avoid data loss. By knowing the causes and applying different troubleshooting measurements, you will avoid these types of errors in the future.
In this post, I will mention and explain the 5 Easy Ways to Repair SMART Hard Disk Error 301 Solutions. Finally, from this article, you will know how to correct this error in common computer models such as HP.
Let's Go to the rid of
Restore BIOS:
The reasons for the SMART hard disk error could also be issues with the BIOS setup. Unknowingly, such malfunctions can occur when you use your device and change BIOS settings. You must reset or upgrade the BIOS to correct that.
Reset BIOS,
Reboot Hard Perform:
A quick restart should be everyone's first attempt to fix this error, but it doesn't actually sort this issue out. Therefore, along with a quick restart, several additional steps need to be taken. One of these is the rough reset. The traces of current present on the motherboard would be discharged from a hard reboot.
Perform hard reboot,
Turn off PC
Check hard drive:
And with the SMART hard disk error there are certain cases where your machine can still boot. You need to check for physical harm on your hard drive in this situation. And make sure there is no loss or defect in link between the hard drive and the motherboard.
In addition, when handling internal parts, you must be extremely precocious because electric shocks and physical injury are likely. Please consult a specialist aid when you do not experience the hardware components.
Refresh your hard drive:
The explanation for the SMART hard drive error often could be ventilation issues. Proper ventilation must be preserved for the regular operation of the hard drive. If the ventilation does not exceed the maximum temperature the hard drive can exceed. As a consequence this error can be obtained when you turn on the device. Ensure that the coolants work properly and periodically clean the internal components to prevent ventilation problems.
Files backup:
As you are all aware, the SMART hard disk error is a simple indicator that the hard drive is about to fail. The first move in this SMART hard disc error is therefore to save essential files. Although a troubleshooting measure does not inherently mean this is an urgent action to be taken. Many hard disc data recovery tools are available for this reason.
If you have a problem with the this error click here Smart Hard Disk Error 301
Toshiba Hard Disk Error 301
Solution 1: Repairing the BIOS Menu
Solution 2: Run a chkdsk Check
Samuel Edelugo wants more answers to this question
wakes up a 6 year old post by Hyjacking it, why do that?
301 means , as stated at HP.com
100000000000 times
the HDD is dead.
ok?
get the PC repaired
or ask how to fix it.
It will fail I bad. 301 I think (hdd dead)
buy a new HDD, better yet a SSD ((yah upgrade it)
buy new OS (if your install media was lost)
install fresh new OS.
end.
buy a new sdd
put it in
installed fresh w7 or 10.
end story
Same on all PCs 2001. if smart tells you it is bad IT IS BAD HDD.
for sure.
dead accurate this post
SOURCE: S.M.A.R.T. Hard Drive fault 301
HDD is failing backup all important data and replace drive, could also try determining the drive manufacturer whether its seagate, western digital etc. and download drive utilities from the manufacturer in an attempt to repair the drive.
Anytime the Error 301 messages appear on your computer, it is due to corrupt or damaged system files.
If you do not fix this error immediately, it can lead to additional system issues, blue screens and hardware problems.
Frozen programs, installer errors, random shutdowns, system freezing and sluggish computer performance are common symptoms of the Error 301.
Fortunately, you can fix the Error 301 with features native to your computer.
Click "Start" and then "Computer." Right-click "C" and select "Properties."
Select the "Tools" tab and click "Check now." Select "Continue" if the User Account Control prompt displays.
Select the "Automatically Fix File System Errors" option and click "Start." Agree to reschedule the check for the next system restart.
Reboot your system.
Allow the check disk to detect and repair all Error 301 issues.
you should have no input while chkdsk utility is in progress any input might further damage your computer it might take some depending on the size of the disk be patient.
Hope this helps
