Goodmans GTVL19W17HDF 19 in. LCD TV Logo
Posted on Nov 07, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Does anyone know if I can use a Goodmans TFT LCD TV, Model: GTVL19W19HD as a computer monitor? It has a VGA socket on the back, but when I connected a computer It wouldn't show.
Buddy Mcsparrin
Level 3:
  • Master 1,684 Answers
  • Posted on Nov 07, 2012
Buddy Mcsparrin
Master
Level 3:
Answers
1684
Questions
Helped
1011620
Points
4641
Yes,
You will need to select the VGA or PC input on the TV and then boot the PC up with the monitor attached so the video card will see it correctly.
3 Related Answers
Anonymous
  • 8909 Answers
  • Posted on Mar 08, 2011
SOURCE: hi, i require the instructions and remote for the
Most major manufacturers supply manuals online so if you were to log on to the manufacturer's web site, you may be pleasantly surprised as usually, if available, one is able to download, by model number, Customer Instruction Manuals, Dealer Network for spare part supplies as required.
The information is normally free of charge.
I hope this helps.
Anonymous
  • Posted on Aug 01, 2011
SOURCE: hi there i have a
Hello. I've just acquired one of these TVs. There is no freeview on this model. However there are Scart and HD connections so it's easy to plug in a freeview or FTA Satellite receiver.
Anonymous
  • 18 Answers
  • Posted on Sep 02, 2011
SOURCE: hi there, i have a goodmans GTVL19W17HD T.V
VGA quality only. If you want to release the high definition features of your TV, use high definition
graphics card together with HDMI cable. Hope it helps. Good day!
HDMI from Virgin cable box to Samsung 400px monitor
should have vga cable and sound cable is the same as the mic cable normal'y green jack on mother board, vga is standard flat screen for computer plugg'es into tv comp or aux will have on tv menu hmi aux,comp
Neither picture is displaying on moniter nor sound is coming (DELL TFT moniter)
Which is a dell tft or compaq crt monitor ?
The Dell 1504FP is a flat panel LCD monitor that has a viewable area of 15 inches.
The monitor, which uses TFT technology, is designed to be used in a home or office and displays video at a resolution of 1024 x 768 pixels.
Over time, you may encounter problems using your Dell 1504FP monitor or it may cease functioning altogether.
Fortunately, there are variety of ways that you can repair the monitor to get it back up and running.
Shut down your computer and press and hold the power button on the side of your Dell 1504FP monitor if your monitor has a blank screen.
Unscrew the VGA video cable that connects the monitor to the computer.
Power the Dell 1504FP monitor back on and wait as it launches into the Self-test Feature Check.
During this period of time your monitor will make settings changes to ensure that it functions properly with your computer.
Firmly screw the VGA cable back into the rear of the monitor to ensure optimal video quality. Power both the monitor and computer back on and wait for your computer's desktop to appear.
Power off your Dell 1504FP monitor if the screen is dirty.
Wipe down the monitor using a dry microfiber cloth to remove any dust particles or smudges that have accumulated on the screen over time.
Power the monitor back on when you are complete and resume using it.
Press the "Auto Adjust" button on the right side of your Dell 1504FP monitor if the display is blurry and images appear out of focus.
Unplug the monitor's power cord for thirty seconds if the problem persists.
Plug the monitors power cord back into the rear of the device and power it back on.
This will reset the monitor and your display should now be focused properly.
http://support.dell.com/support/edocs/monitors/1504fpis/en/trouble.htm
Troubleshoot a TFT Monitor
TFT monitors can suffer from many potential problems, ranging from simple screen brightness issues to disconnected inverter or LCD cables.
These can cause video- and backlight-related failures on your TFT monitor.
Fortunately, you can attempt to repair these problems, even if you have no experience fixing a TFT monitor.
The only tool you will need is a Phillips screwdriver, although opening your TFT monitor will likely void its warranty.
Check the brightness settings on the TFT monitor.
There are dedicated adjustment keys on the bottom face of the TFT monitor.
If it is a screen incorporated into the design of a laptop, you'll find monitor adjustment keys on the top row of the laptop's keyboard.
A TFT monitor that has its brightness turned all the way down will appear to be almost completely dark.
Ensure the TFT monitor's power cable is still plugged in, if it is an external monitor. In the case of a laptop, make sure that the power cable is plugged in or that the battery is properly charged.
Disconnect the TFT monitor from the power source. If the TFT monitor is an external model connected to a computer tower, disconnect the video cable as well.
Remove the battery from your computer if you are using a laptop.
This is an important safety measure.
Turn the laptop over and slide the battery release mechanism over.
This mechanism is just below the horizontal outline of the battery on the underside of the laptop.
Remove the screws on the bezel of the TFT monitor.
The bezel is the plastic piece surrounding the TFT screen.
The screws will likely be covered with plastic seals for aesthetic purposes, so pop these seals off with your fingers and remove the screws using a Phillips screwdriver.
Pry up on the bezel gently and remove it.
Start at one corner and work along the bezel's perimeter with your fingers.
There will be small plastic latches between the bezel and the rest of the computer you'll need to disengage.
Check the TFT monitor's inverter cable.
This black cable lies at the bottom center of the monitor and should connect to a socket on the inverter board, which is the green color horizontal strip that lies just below the inverter cable.
If the cable is loose from the board, the TFT monitor's backlight will fail. Pull up on one side of the socket and slide the cable back in, then press firmly down on the socket to lock it down.
Remove the metal brackets on either side of the exposed TFT monitor if the inverter cable fix does not solve your issue.
There will be two to three screws in each bracket that must be removed using your Phillips screwdriver.
Pull the TFT monitor carefully away from the rear casing of the display to reveal the LCD cable. This cable runs from the back of the TFT screen and should be connected to a socket in a similar fashion to the inverter cable. If it is disconnected, lift up on the socket, slide the LCD cable back in, then press down on the LCD socket to lock it back down.
NOW FOR SOUND
if you can get a screen
Click start control panel administration tools computer management device manager scroll to sound video and game controllers you might see a yellow question / exclamation? ! mark or a red X Right click to reinstall drivers
If your computer came with a motherboard disk the drivers could be on it
or you might download slimdrivers.
Rather doing a driver hunt
http://download.cnet.com/slimdrivers-free/3000-18513_4-75279940.html
Windows XP/Vista/7/8
Note: it will find all of your outdated drivers
This is a free driver solutions
which will automatically search for and find the correct driver
You will have to update every driver individually once you update you might be asked whether you want to restart or make a system restore point.
Click no to both of these then continue updating each driver free then restart once all of the drivers have been updated.
It might take some time being free
1helpful
Hi there, i have a goodmans GTVL19W17HD T.V connected to my computer and and the back of it there are VGA AND HDMI connectors and my graphics card has a vga but it doesnt have a HDMI Connector, but if i...
Hi there i have a goodmans gtvl19w19hd 19inch tv and just wonted to know if it has freeview on it any where as i can not seem to access it if it has it ....
1helpful
2answers
I cannot seem to find a cable to link my monitor to computer do you know were I can get one
Radio Shack if not then Best Buy,if not then on line at Neww Egg or Tiger Direct.
1helpful
Hi there, i was just wondering that, my hdmi monitor which is goodmans GTVL19W17HD monitor and it has a HDMI slot, but my graphics card doesnt, instead my graphics card has a vga and dvi slot, and if i...
Hi hassy786,
Regarding your question if you will use a converter from VGA to HDMI will it provid High Defenition video?
I believe that it will provdie video converting the signal from VGA to an HDMI connection but I do not think that the video will be High Definition since the VGA is just being converted to HDMI signal and not an actual HDMI but just a converted signal, and it is possible that it may not work properly or the LCD TV may have difficulties recognizing the signal from VGA converted to HDMI.
Thanks for chosing Fixya,
avf110686
3helpful
2answers
Hi, i require the instructions and remote for the 19" Goodmans LCD TV model GTVL19W19HD can you help at all>
I hope this helps.
COBY TFT LCD TV/2204 works fine connected to TimeWarner cable without HD box. Get same channels as Samsung TV without box in Kitchen. However, I cannot get my old Compaq laptop to drive the 2204 as a...
the native res. for the TV is 1680 x 1024.
you may want to try a different resolution
like 800 x 600 or 1024 x 768. not the native resolution
of the laptop.
Tv connections
Depending on the model of video card you have, it would be either the VGA or the DVI connector. Many new cards have one of each or 2 of either VGA or DVI.
Many newer LCD monitors can to plugged into either connector, as they have connections for both. There are adapters that will allow VGA to be plugged into DVI as well.
If you computer does not have multiple outputs, you can only plug in one monitor, however.
5answers
Top Goodmans Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
Kolbrun...
ADMIN Andrew
ADMIN Andrew
Are you a Goodmans Televison and Video Expert? Answer questions, earn points and help others
