Question about Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
Have a new Sony Bravia KDL-40W500 keeps turning off into standby mode with 8 flashes.
  • w_a_r_8 Feb 13, 2009
    I have the same problem, only the flashes come in groups of 4. What does this mean? Also, if it is the BU board, where can i get one, or how can i fix it? I hope you can help me out.
    Novelist:
    Scholar:
  • 67 Answers
There is some confusion on the model (KDL-40W500 vs. KDL-40V2500), so I will direct this toward the 40V2500.
On the KDL-40V2500, an 8X blink means the scan processer has gone bad, and the BU board needs to be replaced. If the problem is intermittent, the the AU board might be the problem, but if it all the time, bank on the BU.
A competent repair shop should be able to help you, or you can try calling Sony directly for assitance.
Hope this helps you...
Posted on Jan 05, 2009
  • Rameshra Ra
    Rameshra Ra May 06, 2014
    thanks for tips
6ya staff
SOURCE:
My sony bravia kdl-32s3000 keeps turning off and the standby light is flashing 5 times
Just a copy from Sony:
5X Blink - TCON & HFR Failure
The 5X blink protection mode indicates a communications error between the TCON/HFR board and the MT5388 microprocessor on the A-Board. First replace the TCON/HFR Board if the 5X protection mode blink pattern occurs. If the TCON/HFR Board does not repair the problem then replace the A-Board.
Oct 24, 2012 | Sony KDL-32S3000 32 in. LCD Television
Sony Bravia 46" The standby light flashes four
If tv model number is KDL-46S2000 then 4 times blinking standby light indicates back light failure problem in your tv.
Check/ replace back light inverter boards to solve its problem.
Thanks.
Dec 29, 2010 | Sony BRAVIA KDL-46S2000 46 in. LCD HDTV
Whenever I turn my sony KDL40V3000 on it
Power supply problems. check SMPs and other feed back voltage signals.
Apr 05, 2010 | Sony BRAVIA KDL-40V3000 Television
My Sony Bravia KDL-26S3000 won't turn on and is stuck in standby.
There is a power fault with one of the PCB's inside, contact Sony if you are still in warranty, if not contact a Sony service center as it will need an engineer to open it up to repair it.
Thanks
Oct 09, 2009 | Sony Bravia KDL-26S3000 Television
KDL-40XBR3 turns itself off; STANDBY light flashes 9 times
sony 52 inch tv in stand by mode comes on and off on its own
Jun 01, 2009 | Sony BRAVIA KDL-40XBR3 40 in. LCD HDTV
13 red standby flashing lights -- turns on, then turns off
Are you sure about the 13 flashes. Error code only goes to 8 flashes.
Apr 25, 2009 | Sony BRAVIA KDL-40S2010 40 in. LCD...
Sony Bravia KDL-46Z4100 Standby light flashing 13 times
This sounds like a power source problem! (faulty transformer) I would pack it up and take it back for a new one!
This is a problem you can not fix yourself unless your a pro!
Please rate my response!
Jan 15, 2009 | Sony BRAVIA KDL-40V3000 Television
Sony Bravia KDL-40W4500 turns off
This can indicate a problem with the high voltage circuits. Since this is a new set, it should still be under warranty. DO NOT open up the unit as that will void the warranty. Return the set or request warranty service. Note the 8 blinks when you request service as that should allow them to bring the correct replacement parts.
Keep us posted.
Dan
Jan 05, 2009 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
Sony BRAVIA KDL-40V2500 40 in. LCD HDTV Logo
1,388 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Ekse
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
