You can find Casio Digital Watches User Guides , Instruction Manuals from http://CasioDigitalWatches.com , best site for Vintage Casio Service Manuals.
Thanks
Kashif
VintageDigitalWatches.com
Digital time must be set using pushbuttons on watch case sides. One of them is for MODE, another for SETTINGS.
Mode button usually must be held pushed in for a while to start to work and the digits should start to flash - only then you can start to reset your digital watch using another (settings) button.
Use small steal pin to push these buttons.
If nothing happens, you will have to consult your nearest watch repairer as in this case there is a mechanical or electronical fault.
Rating is very appreciated.
SOURCE: casio telememo 30 syncronising analogue and digital time
To set the analog time to match the digital time...
There are 4 buttons: top left=A, top right=B, lower left=C, lower right=D
Get the watch in timekeeping mode (where it shows the digital time or date)
Press C six (6) times
Hold down A until the current digital time begins to flash
Press D repeatedly to advance the analog time, one minute at a time.
If you need to advance the analog time at high speed, HOLD D DOWN.
To return to regular timekeeping mode, press C
Set the digital time so that it matches the analog time, since you can reset the seconds easily.
SOURCE: how do i change the analogue time for my Casio Aq-180W-1Bvef Mens
If you haven't got instructions on how to do this, you can get instructions from the Casio web site.
Go to the casio web site "casio.com".
Select "support" and the "manuals",
watches;
Accept terms
Select "watch manual archive"
Read the number of the back of your watch and enter it into the search box
Testimonial: "Thank you very much this is exactly what i wanted "
SOURCE: i cant set analogue time on casio hd wrist
Follow this link:
http://world.casio.com/wat/download/en/manual/
Rate, please.
