SOURCE: Water won't drain
make sure there is power getting to the pump if so then your pump has stopped working or may be blocked if not than it will most likly be your pcb
SOURCE: LG WD-3243RHD Front Load Makes grinding, crackling noise
Fixed!
"LE" code Stator/Motor Error.
It was a simple fix and only cost $17.68 at PartStore.com no affiliation.
Hall Sensor 6501KW2001A
http://www.partstore.com/Part/LG+Electronics+Incorporated/LG+Electronics%2fZenith/6501KW2001A/New.aspx
Here is the Service Manual
http://oasisappliance.com/products/lg/LGComboServiceManual.pdf
Bonus, it actually completes a wash cycle and does not stick at 6 minutes, drying forever.
Freakin service tech stated it was the Power Control Board, IDIOT!
While I was in there, I cleaned out the heater blower assembly and sensors. They were full of caked on lint and the sensors had debris all over them.
Also cleaned out all the lint and debris around the rubber seal, this will eliminate those annoying mildew oders.
Hope this helps someone, Happy New Year!
SOURCE: Why won't the drum spin on my LG Tromm front load washer?
I had the same problem and it was a bad sensor assembly (#6501KW2002A). You can order
it from an online electronics store (www.mcminone.com). Cost is approx. $20.
I fixed it based on a thread from 2007:
See http://www.fixya.com/support/t159708-lg_washer_wm1832c
But, here's what I did:
1. Unplug the machine.
2. Take off the back plate that has 4 small screws.
3. Unscrew the big bolt in the middle.
4. Take off the hubcap looking part the bolt was securing.
5. Unclip the two sets of wires on the bottom of the circle you are looking at
(the set of wires to the right are connected to the sensor assembly you want to replace).
6. Unscrew the 6 smaller bolts to take off the circular piece that the sensor assembly is snapped to.
7. Mark with a pen where the sensor attaches so you know where to snap the new one.
8. Unclip the old sensor assembly and clip on the new one
9. Reassemble.
SOURCE: lg front load washer leaking from bottom of machine
I just fixed this problem - there is a rubber hose that hooks the bottom of the drum to the drain and recycle pumps - it is ribbed and it developed a hole. To confirm and repair (repair can be done from the front of the machine)
SOURCE: how do you drain the drain pump in lg front load
There is a small panel on the bottom left front of the washer with a tab on the top middle holding it onto the front of the washer. depress this tab with a small flathead screwdriver and the panel will open downward. You will now see a small round black piece on the left with a flat screw head on it, about an inch in diameter. unscrew this about a quarter of a turn and it will come out with a small hose attached. This is connected to the drain pump. Have a shop vac ready, pull the black plug out of the hose and this will drain the pump. The larger round piece on the right, about 3 inches in diameter is your drain pump. After draining all the water unscrew it with your hand. When you get this out it will have a screen attached which needs to be cleaned at least once a year.
Please rate this post. Thank You.
