CAR MISFIRE AND SCANNER GIVE THE FAULT CODE 107 ;DWELL ANGLE REGULATION AT IGNITING STAGE SHORT CIRCUIT TO GROUND
SOURCE: 03 Taurus with DTC P0340, P1336
I would think it would be just the Camshaft Position Sensor.I looked up the codes and they say pretty much the samething.
P0340
Ford
Camshaft Position Sensor Circuit Malfunction
P1336
Ford
Crankshaft/Camshaft Sensor Range/Performance
SOURCE: misfire in cylinder 1 2001 mercury sable
Next change swap the injector with another and see of the problem moves. If it does it's a bad injector.
SOURCE: 1996 chevy cavalier DIAGNOSTIC CODES
TCC is torque converter clutch circuit which helps tranny shift smoother and is in front off tranny.
$250
Random cyl miss. Most likely bad plug wire or faulty coil pack $45
Transmision pressure switch sends info to computer about tranny pressure and the switch controls it. $400
SOURCE: 2002 Dodge Durango 4.7L V8 Check Engine Codes
1st try and search for a vaccum leak, due to the fact that these vehicles have had some bad problems with the length of wires and hoses, if there is a vaccum leak in the vehicle somewhere that will trigger other malfunctions in your vehicle. Using a can of starting fluid or Brake cleaner spray lightly spray around our engine til you hear the motor rev-up and the spot you have sprayed will determine where your vaccum leak will be. And then check under your distributor cap for any moisture be sure to take a rag and wipe and residue off. Also check the firing order on your distributor.
SOURCE: FORD F150 4.6 L Engine
Several thnigs to check there; review all informastion disponible to do it and solve this...
P0356 - Ignition Coil F Primary/Secondary Circuit Malfunction
The ignition signal from the Powertrain Control Module (PCM) or Electronic Control Module(ECM) is sent to and amplified by the power transistor. The power transistor turns ON and OFF the ignition coil primary circuit. This ON/OFF operation induces the proper high voltage in the coil secondary circuit.
Symptoms
- Engine Light ON (or Service Engine Soon Warning Light)
- Lack/Loss of Power
- The engine may be harder to start
- Engine hesitation
Possible Causes:
- Open or short in the ignition coil circuit
- Ignition coil circuit shorted to ground
- Ignition coil connector
- Damaged ignition coil
- Damaged PCM or ECM
Possible Solution:
- If damage, repair ignition coil circuit
- Replaced ignition coil
- Replaced PCM or ECM
P0152 - O2 Sensor Circuit High Voltage (Bank 2 Sensor 1)
The heated oxygen sensor 1 is placed into the exhaust manifold. It
detects the amount of oxygen in the exhaust gas compared to the outside
air. The heated oxygen sensor 1 has a closed-end tube made of ceramic
zirconia. The zirconia generates voltage from approximately 1V in richer
conditions to 0V in leaner conditions. The heated oxygen sensor 1
signal is sent to the ECM. The ECM adjusts the injection pulse duration
to achieve the ideal air-fuel ratio. The ideal air-fuel ratio occurs
near the radical change from 1V to 0V.
Symptoms:
- High Fuel Consumption
- Excessive Smoke from Exhaust
Possible Causes:
- Harness or connectors (The heated oxygen sensor 1 heater circuit is open or shorted.)
- Front Heater oxygen sensor heater (Bank 2) may be faulty
Possible Solution:
Replacing the O2 Sensor 1 usually takes care of the problem
P0174 - Fuel Injection System Too Lean Bank 2
With the Air/Fuel Mixture Ratio Self-Learning Control, the actual
mixture ratio can be brought closely to the theoretical mixture ratio
based on the mixture ratio feedback signal from the heated oxygen
sensors 1. The ECM calculates the necessary compensation to correct the
offset between the actual and the theoretical ratios.
In case the amount of the compensation value is extremely large (The
actual mixture ratio is too lean.), the ECM judges the condition as the
fuel injection system malfunction and light up the MIL (2 trip detection
logic).
Symptoms:
- Excessive Fuel Consumption
Possible Causes:
- Intake air leaks
- Front Heated oxygen sensor may be faulty
- Injectors may be faulty
- Exhaust gas leaks
- Incorrect fuel pressure
- Lack of fuel
- Mass air flow sensor may be faulty
- Incorrect PCV hose connection
Possible Solution:
Dirty air filter of faulty air flow sensor are common causes of the problem.
P2197 - DODGE - Sys Too Rich at Hier Load Bank1
Means that the O2 sensors on each bank are seeing WAY
too much oxygen in the exhaust gas. In normal operation the signal from
the O2 sensors should swing back and forth between rich and lean.
Your sensors are locked on lean.
Those codes are the same as P0174 (and P0171). Sounds like you have a
vacuum leak somewhere. Most common place is the PCV elbow where it
connects to the throttle body adapter.
Hope this helps; keep in touch.
