1973 model 1 humbucker 2 single coil with toggle switch and 5 way switch,plus 2 tone contol and one volume control
SOURCE: Problem with volume dials in an electric guitar.
If you can't clean the pots or if you just want to try replacing them, try using
500k pots again, in case one or both of the pots is worn or dirty or
defective. If that doesn't work, and cleaning or replacing the
switches doesn't work, then the problem is probably elsewhere.
You could put a 500k resistor (with a sufficiently-high power rating of at least half the power rating (Watts) of the pot) in parallel with the pot, or, to cover all bases, put a 500k resistor from each of the two outer lugs of the pot to the middle lug. That should change it into the equivalent of a 250k pot. You could even just temporarily clip the resistors on, with alligator-clip leads, if you're very careful, just to test it.
Good luck,
The dude.
SOURCE: I need a wiring diagram for a dean v bass (ev or
Match your resources of your guitar at this site to find typical schematic:
http://www.guitarelectronics.com/c=t6JiCQzmaFtGBjJUnATWv1XQ2/category/wiring_resources_guitar_wiring_diagrams/
SOURCE: i recently purchased a dean "dime-razorback"
here is a wiring diagram for another washburn. its not gonna be exactly like your set-up, but it should be pretty close. its really not that hard to rewire a guitar, i did it when i was like 12 years old, and the worst thing i did- wired the volume pot backwards. the diagram im seeing is differrent from any guitar ive prevously worked on, but it should be pretty accurate for a washburn.
http://i83.photobucket.com/albums/j298/BlueBuddhaibanez/Picture12-1.png
those dimabag darryl guitars, lke the bronze ones, are really cheaply made.
