Originally the belt was slipping so I replace it. It was worn out. But now after finishing the previous spin cycle, I put another load it in and it wont fill, the timer doesnt work...It acts as if its not plugged in, but it is. I have an electrical back ground, but the schematic provided doesnt tell me much. It eludes to a breaker or fuse but I cant find it on the unit.
SOURCE: Maytag Atlantis wont run
JC, sounds like the lid switch, check this first and post back..Catriver
SOURCE: Maytag Model # LAT9635AAE
Check to see if it is a pump problem or a transmission problem. First remove both belts see if all the pullys turn freely. if the pump has a tight feel check inside pump for a item jammed in it.look for transmission oil on floor or belts if oil is present transmmision if probably going.ALSO check at the top of the tubs for anything stuk in between tubs.
SOURCE: Maytag Atlantis MAV6257AWW
I have a Maytag Atlantis MAV6257AWW. I need to replace the transmission. So I removed all four screws from the inner tub but I couldnt get the inner tub pull out, it's stuck.
From what I read on here, the seal nut doesn't have to be remove in order to remove the inner tub.
I tried every, I even hammer the shaft down from the inside of the tub but still no luck. Can someone help, thanks.
