I got an error code on my dryer and just wondered if there was a place where all the codes are listed.
Frigidaire standup deepfreezer. Model: LFFH21FHWC; SER.: WB91736718. Had 9. Hi tempture on face, & its thawed my food out
Take top off look inside & there should be a Tech Data sheet,with codes on it.Look close,becase some times it tape tight to the wall
There are several websites with error codes listed. I have not seen any codes listed for frigidaire dryers. So I checked at Frigidaire.com had no luck there either. 800-374-4432 is their customer service number. I found codes for Frigidaire cooking products but nothing for dryers. Good luck.
I appreciate your post, Aeraci Los Fresnos!
From the information you have provided your Frigidaire dryer is providing an error code of "E63". The "E63" code stands for heater to earth has been grounded, this could be a possible issue with your heating coil or connector. I would recommend performing a reset on your dryer and you can do that by flipping the household circuit breaker off for roughly ten minutes this will help clear out any miscommunications. If you continue to experience an issue with the "E63" error code I would suggest consulting with a professional technician come out and provide an accurate diagnosis for repairs. Best of luck! -OOS
Good Morning Yasmin Abdullah, I am happy to assist you!
Based off the information you have provided your Frigidaire dryer is displaying error code "E64". "E63" typically stands for heater open circuit, which means that it could be a faulty wiring harness or heater. I would suggest performing a reset on your dryer by disconnecting power from it for ten minutes. This could be a false error code or a miscommunication within the board and a reset will help to clear that out. I hope this information is helpful to some degree. -Matt
