I tried unplugging the roku box and checked my HDMI cord on another product to make sure it was not the problem.
I have a 50” Sharp Roku TV and the screen is black but has sound don’t know what else to do I have reset it and even unplugged it everything even plugged it into a different outlet and still black but has sound what can be the problem
I just had the same issue. I only disconnected it from the usb charging then reconnected and now it works just fine. I've had this for a few months now and this is my 1st issue.
Out of the blue, my ROKU had sound but no picture.
To correct, I unplugged the Roku for 5 minutes. I restarted the Roku and the problem was corrected.
SOURCE: No surround sound when attaching hdmi to TV
Try running the optical TOSLINK cable from the TV to the receiver. If the TV doen't have a digital optical output, then try going into the menu on your cable box and setting the audio output to the digital optical out. Also check your TV menu and make sure NETCOMMAND is diabled. Some of your newer HDTV have Netcommand that allows the TV to control other devices through the HDMI cable.
SOURCE: The LCD screen is dark with no sound or picture when turned on.
I had the same problem after having a Vizio for 2 and a half years. I
left the room for a minute, i came back and the screen went black.
There was still power to the unit and you could see that the back light
was working, just no picture, no sound, and you couldn't use any of the
buttons. The only way to turn it off was to unplug it. It would then
start up, with the Vizio logo going from orange to white, and then do
the same thing all over, no pic or sound.
HOW I FIXED MINE:Look through the back vents for a white light to make
sure the backlight still works. I ordered a new "main PCB" from
tigerdirectparts.com
(you can also use searspartsdirect.com). This is the circuit board with
all of the inputs on it (hdmi, cable, etc.) I opened it up,
disconnected the old one, put in a new one and now it works fine. I
used
both serial numbers on the board to search for it online. It cost me
$144 to do it, but that's better than $450 for a new TV. My tv is the
vx32l hdtv10a. I hope that helps.
For me the part number was either (depending on the vendor) : 0171 2272
2174 or it was 3632 0212 0150. Check your circuit and see if any of
those numbers match up.
SOURCE: HDMI signal cuts out for
Mine did the same thing where the screen would go black for a few seconds and then the picture and sound came back. I would try (1) switch HDMI cables, (2) try a different HDMI input in the back of the receiver, (3) try different input in the back of the TV. None of these seemed to work with mine. I finally ended up running the cable box direct to the TV and only run the audio through the reciever via coax or digital. No more problems. I think the HDMI inputs in the back of the reciever have a problem continuously carrying the signal if it is the leaset bit weak.
SOURCE: I have just purchased a
If you are trying to connect it in composite mode (the one yellow video cable) it won't work with the PIP turned on which is how it comes from factory. This is crazy as it means that you cannot see anything (menus) on the screen to disable it. I have a walk through guide here to turn it off blind or the other option is to take the STB and connect it to another TV via Component or HDMI and then turn off the PIP.
