Question about Kenmore 24902 Top Load Washer
Kenmore 80 washing machine won't spin
It will actually spin but it is very, very weak. It won't even
begin to spin with a load in it. I can get it to slowly start
and get up to speed with it empty....no wet clothes in it.
Something to do with belts?
Thanks for your help.
  • mort399 Jan 05, 2009
    mine will spin sometimes
  • 113 Answers
No belts on that washer. You need a new clutch, the clutch cant grab the basket drive tight enough to spin. I will try to add a tutorial on it tomorrow. Look here for tutorial. www.shop.washermd.com Dave
Posted on Jan 14, 2009
6ya staff
SOURCE:
Kenmore 80 series washer won't spin or agitate
check to make sure the belt hasn't come off. if it's direct drive make sure the shaft is working and moving freely. if all of these check out the motor that turns everything my be stuck, frozen up or just bad all together.
Jul 14, 2012 | Kenmore 24032\24036 Top Load Washer
Need a diagram for Kenmore 80 series top load washer
Please check this link for the position of the parts:
http://www.espares.co.uk/advice/washing-machines/a/7/311/how-to-identify-washerdryer-parts.html
check the capacitor to the motor as if this is weak the motor will not start up.
Jun 28, 2012 | Kenmore Washing Machines
My Kenmore 80 series washer won't spin, and it just makes a loud gear grinding noise. What could this be, and how do I fix, in the simplest form please I'm chick... :)
rebecca it is probably the motor coupler. Move or slide ur machine over and if there is ruber filings under it then it is the coupler.
Apr 04, 2012 | Kenmore 24032\24036 Top Load Washer
Kenmore series 80 washer won't drain after wash cycle
Try the 'drain' portion of a few of the other cycles (heavy, perm. press, delicates) and see if it will drain/spin there. You can also try advancing the timer slowly through the 'spin' portion to see if it kicks in anywhere.
If it will rinse and spin in the other cycles, you most likely have a bad timer.
Hope this helps.
Sep 25, 2011 | Kenmore 22422 Top Load Washer
My washing machine will wash, but not spin. What should I check first? Kenmore 80 series
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Apr 15, 2011 | Kenmore Washing Machines
Kenmore 80 series model 22832100 does not always spin fast enougf
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
heatman101
Sep 03, 2010 | Kenmore Washing Machines
Kenmore 80 series. RUNS LOUD, THEN TURNS OFF AND RESETS...
you have something gotten into your pump ,,, it trys to drain and spin but overloads the motor and shuts down till the motor switch resets .... remove the pump and take out whatever gotten in it and if that not possable replace the pump.
Nov 24, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore 24902 Top Load Washer Logo
56 people viewed this question
fordexpert
Harvey Mahal
Kristen Denison
Kristen Denison
Level 1 Expert
