SOURCE: GE Washing Machine
Sounds like you have a bad fill valve on the cold water side. If your hoses are not clogged, then remove the hose and check the cold water inlet going into the machine for clogs. There is a screen that can trap mineral deposits and/or rust. If you have well water or hard water, they can become clogged easily. Sometimes you can clean them out and they will work just fine. Most of the time, however, you will need to replace the fill valve. Make sure you unplug the machine and turn the water off. The valves are electronically controlled. I hope this helps.
SOURCE: Fixing a clogged pump on GE Profile washer
waht u need to do is get a bucket now take the outlet hose and place it into it low to the ground if water comes out then it will be that your pump is faulty and needs replacing but if it doesnt the only way to do it is towels on the floor and with a low pan place this under the sump hose which should be in the middle of your drum which then leads to the pump pull slowly but not enough for the water to push the hose of do this until empty the only other way is to take it outside and pull the outlet hose of this is the quicker and dryiest out of them all but do do the first part to c if the pump is faulty m8
SOURCE: How do I open my GE Top Load Washer to check for leak
Pull the washer foward, tilt back against the wall and look under it.... look where the water pump connects to the motor shaft... check for rust etc.... if so replace pump....
SOURCE: Washer leaking water from bottom
looks like you have to replace the RUBBER SEAL thats inside the tub at the center post , try this , remove the panel so you can see inside , put the washer to fill w/ water , and watch closely underneath the tub wheres the transmision is connected , and watch for LEAKS . hope this info helps
SOURCE: GE Profile Washer leaking underneath during spin cycle
its your outer tub it has a hole in it
