ViewSonic VX900 19" LCD Monitor Logo
Eddie Bresnahan Posted on May 24, 2007
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
PC starts fine, then the montor blinks and no display. light stays green
I have a VX900 monitor, I'v connected the monitor to other working PC's and what happens is that the monitor amber light comes on stays green but then the display go black, I turn the monitor on and off and you see the windows XP desktop fine then the monitor goes black again aaand the light stays green. You can continue to power on and off with the same results you saee the background then it goes blank. Any idea?
A
Anonymous
It's hard to identify the capacitors though. Any thoughts on how to do this or where to get them?
Thanks
Rog
electronic & computer repair& servicre
Level 3:
  • ViewSonic Master 12,061 Answers
  • Posted on Jul 24, 2007
ViewSonic Master
Level 3:
Answers
12061
Questions
0
Helped
4006069
Points
36390
This is most probably cause by one or more Faulty Electrolytic Capacitors, I find these are the MOST commonest form of "Fault" in these LCD's TFT's units. I ususally simply replace "On Spec" all High Value Electros, in fact ALL Electro's are suspect and often I just "Shotgun" and replace 'em all. Usually fixes all problems. Always use High Temperature Caps. Try this as it is a common problem I find a lot. Good Luck.
Montor blinks white
If this monitor is new return it to the place of purchase, the problem is in the LCD panel display, if out of warranty! cheaper to replace.
1helpful
Monitor light is green but display is black
your power supply board, probably has some bad caps in it
1helpful
Vx900 no video display or on screen display. When powered up video signal displays for less than 1 second and then is gone. Power LED is stays solid green on, have tried other monitors and video signal is...
This monitor has a back-light problem and it could be a faulty inverter board or a faulty CCFL lamp.
For service parts and DIY info, check out LCD Parts, please click on this link to their WEB site :-
www.lcdparts.net
2helpful
3answers
What does the red light mean next to the power button?
The red light next to the power button is usuall the hard drive led which should blink every time the hard drive is in use, there is normally a green or yellow light for the power that shoukld stay on constant when the computer is on.
AcerAL1714 LCD Not Connecting With DELL Inspiron 15 Vista Laptop
There is a symbol of Two monitors on F3 Or F4 button
1. Press Fn key and hold it
2. by holding Fn key press F3 key
Your monitor will start displaying
Blinking lights when PC is turned off
This works if you boot the monitor with a pc, open the osd menu and go to reset. reset the monitor.
Monitor won't display.
I would suggest that the "Event" that caused the CB to trip has caused ya Monitor to fail.. Probably in the Power Supply, My "Pet" area... lol.. anyway Thats wat I would think. It may even have an internal "Fuse" that has "Blown"?
Top ViewSonic Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Rob Hill
Rob Hill
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
