Mackie PPM608 / C300z PA Package Logo
Posted on Nov 10, 2012
How do i open up a mackie ppm608 - Mackie PPM608 / C300z PA Package
1helpful
Mackie dl1608 faders are hard to move when ipad docked
Hello, check if your Mackie, is with the latest Firmware update, you can get it on Mackie's official website
I sent you the Mackie technical support link
I hope you solve your concern
Greetings Franco Dosil
Hola, revisa si tu Mackie, esta con la ultima actualizacion de Firmware, puedes obtenerla en la pagina oficial de Mackie
Te envio el link del soporte tecnico de Mackie
Espero logres resolver tu inquietud
Saludos Franco Dosil
https://mackie.com/blog/support
DIGRAM MACKIE PROFX16
Hello Abel, I sent you the link to download the service manual of the Mackie PROFX16
I hope you can solve the problem you have with your Mackie
Hola Abel, te envio el link para que descargues el manual de servicio de la Mackie PROFX16
Espero que puedas resolver el problema que tengas con tu Mackie
https://elektrotanya.com/mackie_profx16_profx22_sch.rar/download.html
I have a Mackie 406M Powered Mixer. can't get sound out of it anymore. all the input level set lights stays on. any suggestions
That sounds like the amp board died. Mackie parts can be hard to source, and Mackie is really slow to ship, so I suggest taking it to a Mackie authorized service center. Here's a link-
Contact Support Mackie
Mackie PPM608 powered mixer
From the way you have worded the question, I would say you're in no way certified to do this. Take it to a professional.
I can not locate the fuse for a ppm608 amplifier
It is located on the Power Supply PCB next to the ac line voltage plug.
I need a schematic for a Mackie 2404-vlz mixer
Upon opening the mixer, you might find that the preamp boards are
similar , use the running board as a guide in troubleshooting .
On most are the XLR inputs with phantom supply.
I. Have a profx12. I am running just into laptop.i want to use my jvc receiver to playback recording instead of listening through headphones. Is this possible.
it should be if you hook something up to an input channel like w the band i was in i had to hook my turntables up to a microphone jack on an open channel . so yeah if u plug lets say a cd player plug the output of that into the input of the mackie and make sure you have your speakers in the output of mackie all set up and it should work no problem. We have the same mackie
How do you get inside to the horn on a Mackie c300z? I need to replace horn diaphragm.
You use a VERY long phillips screwdriver as there are screws in those deep wells from the back. I think it takes a #3 phillips and you want one with at least a 12 inch shaft to reach the screws. The screws are black and are Kaylon or sheet metal types with pan heads. It can be a little tricky to engage the screwdriver bit as deep as these are.
Make sure ALL screws are completely out... count them vs the number of wells... there are a lot!
Then you have to pry the back off.
Where can I get New master faders for Mackie 1604 ? I live in banbury.
Your best bet is to visit the link below and select the "local distributor" option under section 4. You will then get contact information for a local distributor. I have found Mackie to be very helpful with parts requests. Please note that these units are a bit tricky to open up. Take care during dis-assembly not to tear any cables.
Dan
Link: http://www.mackie.com/support/
Top Mackie Music Experts
 Grubhead
Grubhead
Grand Canyon Tech
Grand Canyon Tech
ADMIN Andrew
ADMIN Andrew
Are you a Mackie Music Expert? Answer questions, earn points and help others
