SOURCE: Panasonic SC-HT75 won't read and play DVD Movies and play CDs
you may clean the lens, then try to play dvd's again.
SOURCE: blu ray connect to my sc-pt660
Why not leave the audio into the TV via HDMI from the Bluray and then optical audio out from TV to the home theater audio system? Same as the hook up for the cable box. The SC-
PT660 only has one optical audio connector so your solution may not be feasible assuming he's also got a cable box connected to the TV.
SOURCE: How to unlock and make the Panasonic Blu-Ray Home
It doesn't look like you can change the region code I uploaded the manual here (http://www.superfi.co.uk/extras/Panasonic/Panasonic-SCBTT755-manual.pdf) page 11
SOURCE: I purchase a Panasonic Blu-Ray Home Theatre
Hello there,
Yes it is possible and relatively simple to do. I suspect you have only connected an HDMI cable from the Home Theater system (HT) to the TV. This cable only sends audio and video to the TV from the HT system - it can't be used to receive the audio from the TV back to the HT.
To get audio from the TV channels through the HT speakers, you will need to connect a separate audio cable from the AUDIO OUT sockets on the TV to the HT. This can be either a Digital Optical cable (connects to socket ringed in green) or an RCA type stereo audio cable (connects to AUX sockets ringed in red).
If you are using a cable or satellite receiver, you should connect the receiver directly to the HT rather than the TV. You would also need to select the correct INPUT on the HT when you want to use the speakers for the TV channels. This will be DIGITAL 1 if using the digital optical cable or AUX if using the RCA stereo audio cable.
The audio connections are explained on page 16 of your user manual and input selection is explained on page 23. If you don't have a manual, please let me know and I can supply one.
I can draw you a diagram showing how to connect your TV to the HT and provide step-by-step instructions for setting it up, but you will need to let me know the brand and model number of your TV. If you are using a cable or satellite receiver, please let me know the brand and model number of this receiver as well.
Hope this helps.
Regards,
BElectric
