Agitating very slow
Replace the agitator dogs. Here is the kit to order.
Below is a video to show you how to make the repair.
SOURCE: Whirlpool Ultimate care II Washer Agitator not turning
replace the dogs in the top portion of the agaitator, the agaitator top comes off and you will see the four dogs part number is 285707 about 3-5 dollars
SOURCE: Whirlpool Ultimate Care II Plus Washer Model: LSQ9264HZ0
if you hear the motor running while it is supposed to be agitating or spinning then it is most likely the direct drive coupling between the motor and transmission. if you already checked this and think it is a different problem then let me know, i will help you figure it out. Mike
SOURCE: Whirlpool Ultimate Care HD Plus Model #LSR8233EQ0 won't agitate or spin
It sounds like the coupling between the motor and gearbox has worn out. It should cost around $15 plus shipping and handling.
SOURCE: Whirlpool ultimate care II super capacity plus
If the bottom half of the agitator is turning and the spin cycle works, then the motor coupling is good.
Check the agitator by turning it back and forth. It should work like a
ratchet (turns one way, locks the other way). If you're able to turn it
in both directions, the agitator dogs are worn and need to be replaced.
To do this remove the agitator cap and the bolt that holds down the
agitator. With the bolt out you can remove the top section of the
agitator (auger) where you should see 4 small white or beige plastic
gears (dogs). Replace those and it should be ok.
The part number is 80040.
If it there is no agitation or spin, replace the motor coupling.
The part number is 285753A
