My camera will not charge or start up and is open with the lens extended.
SOURCE: Kodak z730 lens
Ok found out my particular fix...
Had to recharge battery 2 times in a row, no idea why this worked.
Camera now operating as usual.
SOURCE: Lens comes out, then retracts after charging.
If this camera has a rechargeable battery in it You Will Have to Get a new battery for it(Your Description indicates a Bad Battery Cell). If it uses AA Rechargeable Batteries they will Need to Be Replaced.
SOURCE: it will open the lens and extend but then closes
You might not need the warranty KODAK can see the manufacturing date of the camera from the serial number. However it might not be the same as the purchace date since the shop could have had the product in stock for a while.
Here are the steps:
1. Make sure you will install a new or fully charged battery/batteries into your camera.
2. Clean the battery contacts.
a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth.
b. Reinstall the battery/batteries into your camera
3. Without the memory card,turn on your camera.
4. Pls test with an alt. batt.
If you do not have access to a dif. battery.
Pls. take the batt out of the camera. Insert the charger into the unit from the main socket and turn the camera on. If the camera works you will need to replace the batt. If not you will need to order a No power repair.
Contact KODAK:
http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
SOURCE: M863 lens extends and then immediately retracts
Kodak Easyshare cameras use Li ion batteries, as recommended by the manufacturer, which have higher voltages but not necessarily higher amp hours per battery pack.
When I first bought my 14.1 megapixel camera from Kodak, I tried various batteries, including Alkaline, Ni MH, and they didn't work very long before needing replacement or recharging.
This is because the voltage isn't enough on other batteries.
I do not understand why they make it this way, because it fooled me a lot. I thought that since it had a AA format that it would be alright to use AA batteries of any type in the camera. But, this is not so, in my experience.
Good luck getting your camera to work with new Li Ion Batteries.
Note: if the Li Ion batteries do not work, then there is something wrong internally with your camera.
Contact kodak.com to see if it is economically repairable.
Thanks for asking a question on Fixya.com.
SOURCE: When I power up the
Have you made sure that the batteries are LiIon and fully charged? I had a similar problem with a Kodak Easyshare camera that required the higher voltage LiIon battery pack rather than alkaline AAs which will fit in there but is not exactly right.
