Splendide 2100XC installed in RV Plugged RV into bad electrical receptacle, lost Washer/dryer, convert/charger and microwave Washer/dryer does not power up, can it be fixed
If your appliances all blew they may have been fuse protected, such as tv's and microwave have inside them. Power converter should be fuse protected as well. If the plug was wired incorrectly was it a fifty amp service or thirty? Does your power run threw a transfer switch? look there as well. typically voltage spikes threw ground circuits take out your electronics. Using ground fault interruption circuits and voltage protectors in between your plug and power supply will prevent most/some damage. many variables to pinpoint without input.
Replaced burned out surge protecter in washer
