I have opened the back and all of the caps look good, but the TV will not turn on. What do I do?
SOURCE: Viewsonic N3760W won't power on
Try unplugging the set from the AC power source wait for several seconds and then plug it back in. Cross your fingures and hope that the reset works!
SOURCE: I was playing my xbox 360 on my viewsonic tv and it just went off
From the symptoms it sounds like the TV requires an Inverter PCB.
This is the part that "lights" the screen.
I hope this helps.
SOURCE: No power to viewsonic N3252W lcd
TRY THIS SITE OR GOOGLE YOUR MODEL #
http://www.free-service-manuals.com/
SOURCE: My ViewSonic N3252w screen goes
The backlight inverter is failing for your tv. You need a direct replacement part. You can find parts on ebay or shopjimmy.com and you can search my the model number of the tv. Once you get the part, allow your tv to be unpluged for 12 hours before beginning any work. This will allow charges to dissipate and allows for a safe work environment. Once you replace the part you will be good to go. Also, check the power supply for popped capacitors while you have the tv open. Replace any bad capacitors with the same uF value and HIGHER voltage value (EX: 1000uF 10v --> 1000uF 35v)
Thank you and please rate.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
