Have not been able to get the dryer to respond - tried to get it to do diagnostic mode but nothing there. Rotated the drum by hand back and forth, got a response, with the Drying LED on (16 value) but that was all.
SOURCE: Fisher and Paykel dryer not drying
I've had this problem for 3+ years. There are possibly multiple reasons why your dryer trips the reset switch. My dryer has a design issue with the lint trap, in that it allows lint to build up around what I assume is the heat sensor / thermal switch. It's simple, the temperature is detected as too high in the dryer and trips the switch which cuts power to the heating element. The reset switch access as mentioned in other posts requires either tipping the dryer back or removing the front panel, at least partially, to access the switch. After the reset switch is pushed, you'll need to check if there's lint built up that's causing the reset issue. First, find the reset switch.
To access the switch, there are 4 Phillips head screws that need to be removed. For the first 2, lift the dryer lid and you'll see two half-moon shaped rubber inserts at each of the front corners of the machine. The inserts can be pulled out with your fingers or use a screwdriver, gently. There is 1 screw under each insert that needs to be removed. Once those screws are out, you can put the lid down and lift the plastic top of the dryer that the lid normally rests on. It's attached on the back of the dryer so don't worry, it won't come off...it will lift just like the dryer lid. Be careful of the sharp sheet metal edges. Now there are 2 smaller screws, 1 at each front corner, that attach the sheet metal pieces. Remove each of those screws. To get the front off requires a bit of finesse. You'll see that the front sheet metal panel of the dryer has bends in it to attach it to the sides of the dryer. Gently pull at the top corners, one at a time, to separate the front panel from the rest of the dryer. You'll see that there are u-shaped orange or red plastic pieces inserted into the sheet metal sides that align with holes in the front panel to hold the skin of the dryer together...the front should just pull away from those u-shaped pieces. There is a wire with a clip attached to the bottom of the front panel, probably a ground wire...if it pulls off when you remove the front panel, just reattach it when you put everything back together. The front sheet metal is also integral to the front feet of the dryer, so tilt the top of the front panel toward you and lift. The front panel should pull away. When you put the front back on the dryer, do it feet first by aligning the plastic foot pieces, then align the u-shaped side pieces, then worry about the top corners wrapping back around so the front fits flush.
The reset switch is in front at the bottom right of center and is probably orange. Just push it and you'll hear it click. I would vacuum out the lower part of the dryer at the point, but it's probably not what's causing your problem. I've gotten to the point where I use a yard stick or vacuum extension to push the switch without completely removing the front panel. Then I don't have to detach / reattach the ground wire. You'll see after you do it 3 or 4 times!
Now check to see if lint build up is causing your thermal switch to trip. Pull out the lint trap and you'll see 1 Phillips head screw behind where the lint trap normally sits. Remove the screw, and you'll feel the circular plastic piece the lint trap sits in become loose...pull this round piece out of the dryer from the bottom. If there is a lot of lint behind this circular plastic piece, that's probably what's tripping the heat sensor. Vac it out. Gently feel around the circumference of where you removed the piece to see if the fine mesh lint screen has any holes (if it does, it may be blowing lint into your exhaust and eventually clog the vent to the outside). If the mesh is torn, I assume that larger circular piece needs to be replaced at some point in whole or part. From what I can see, the design of the lint filter and trap is ....****. The system allows lint to enter the area where the heat sensor sits.
The short term fix is to vac out the sensor area regularly and that will keep the switch from tripping, if that is your actual problem. I believe F&P is aware of this issue and will probably remedy it for you. I called them once when this issue originally happened and had to wait for a tech to come out do what I described above. I haven't called them since, but have seen other posts regarding a new part or parts that F&P will provide...hopefully free! Good luck!
SOURCE: Cannot find the reset button
You can download parts diagrams here
http://fisherpaykelparts.net
SOURCE: dryer tries to start - then stops and beeps PLEASE HELP
Check the exhaust hose. If the dryer isn't venting properly it will either stop or the heater will turn off and the clothes will remain wet. If the hose is not clogged check the wall vent tube.
SOURCE: Fisher & Paykel Auto Sensor Dryer stops & beeps constantly
Hi emkboyce
my Fisher Paykel auto sensor dryer keeps stopping and beeping, i have to stop it and and re start.
I had the same problem. I took it off the wall and vacuumed up all the lint from everywhere including around the back and including taking off the back and vacuuming everything I could reach inside. I then used a damp cloth to get rid of the rest of the lint/dust.
I thought I was wasting my time but guess what, the problem has gone.
SOURCE: my fisher and paykel dryer ( mod# ED56 ) wont start, power is on
I had this same problem with my Dryer. It is making the few quick beeps because it thinks the door is still open. Near the bottom of the opening to the dryer there is a sensor switch that gets pushed in when you shut the door. Try holding the switch in with a knife or something and then start the dryer with the door open to check if that is the problem.
After i did this, i closed the door and my dryer started as normal.
SWAJCOBS solution solved it for me - major lint build up - cleaned it out and all was good...Many thanks to him for his help.
