Pump wiring diagram
SOURCE: lg wm-14445fds direct drive 8kg washing machine manual
You can get the manual here:
http://uk.lge.com/products/sidemenu/list/homeappliances|washingmachine|steamdirectdrivewashingmachine_PRD|MANU_manu.jhtml
Just curious - what happened when you tried to get in touch with LG? Also, did you call, email, what?
SOURCE: need timer wiring diagram for direct drive
Most washers have their wiring diagram glued to the inside of the removable panel on the back. You need to unscrew the panel to get to the diagram.
SOURCE: I have a model WM2688HNM
undo the screws at the back take the lid off then pull out the dispenser draw take two screws out holding front display on then jiggle the display out might be lugs or clips holding it in place as well then take the bottom kick plate off lever it with a flat blade screw driver it just pops off then open door take door lock screws out then take spring off the door gasket then undo the screws on the top & bottom of the front panel then your in
