Sadly not. The HP Photosmart C7280 insists on having a full set of cartridges installed in order to print. It does this because the printheads are actually part of the printer itself and can sustain damage if they pull air into the printhead.
The out of date message is also non-negotiable I am sad to say.
The black ink cartridge is larger than the photo black cartridge and black is used in photos to make the darker colors. Black text takes much less ink per page.
Your only problem here is that you own a HP inkjet printer. This printer uses up both cartridges even if you print in black. Donate this thing and get you a Brother laser printer that just prints in black. This will cost less to operate per page and uses less energy.
Check the print properties and verify the black ink cartridge still has ink in it.
Otherwise, you may have a bad ink cartridge. If the cartridge has not been used for a while, the ink gums up the nozzle. You can try cleaning the ink cartridge and slot with alcohol. However, new color and black cartridges may be the best solution.
Why don't you try changing the Setup for your printing to Black & White or Grayscale in your computer's software: File/Print/go to the printer's settings and disable anything color. As for the cartridge, it's probably the cartridge. If you have an extra, why not swap it out? I believe the brains in the cartridge contacts might not be working properly OR your heads need to be cleaned OR you better stick with HP original cartridge to make sure it's not the printer. I used to use "odd" ink and even refilled ones and shortly thereafter my old printers would die. Not taking a chance on this HP. I love how it prints when it isn't jamming the paper! Need help on that problem pronto.
sounds like its a expired ink issue. on alot of the hp photosmart printers the ink has a expirey date on the carts the best solution would be to contact hp and chances are they will send you free carts if your ink has been expired. when a black ink is almost out most of the time it trys to draw ink from the color carts mixing to make the appropriate color.
but you can also try the following.
See the instructions for
calibrating a print cartridge in
the Care and Maintenance
section of the HP Photosmart
Printer Help.
HP Inkjet printers work only if both the cartridges have ink unlike HP Laserjet printers.
If you want the printer to print only in black, Follow the steps
Start --->Control panel -- >Printers and faxes ---->Right click on the printer icon (HP c5100) select printing preferences.
Under printing prefences there u will see an option to print with black or print in gray scale.
Note:HP Inkjet printers like Photosmart C5180 will work only both the cartridges have ink.
