When i turn on only half the screen shows
If the half portion of the screen is only black shadow the the cause is either busted screen back light or a dry connector at the power inverter board. to access this part you will need to remove the back cover of the tv unit. the power inverter board installed near the power supply board and then the screen back light is mounted at the upper and lower portion of the panel display covered with metal shield.
