Panasonic Lumix DMC-FX01 Digital Camera Logo
klodian jovani Posted on Nov 12, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I can not clear the note "please turn camera off and then on again"
This note stays allways iven if i restart the camera
KHATRI CAMERA
Level 2:
  • Expert 67 Answers
  • Posted on Nov 13, 2012
KHATRI CAMERA
Expert
Level 2:
Answers
67
Questions
Helped
23669
Points
150
This problem comes out for lance issue,if you are technician then open your camera and proper clean your lance, or put to any repairer for service your camera properly , don't warry its a routine problem of camera .
[email protected]
Hello guys, I have a fast booting loop problem
A boot loop is a common issue that can occur on a computer or mobile device where the device continuously restarts or "loops" through the boot process without fully starting up.
Here are some possible solutions for a boot loop problem:
  1. Restart the device: Try restarting the device by holding down the power button for a few seconds until the device turns off, then turn it back on again.
  2. Boot into safe mode: Try booting the device into safe mode. This is a troubleshooting mode that allows you to access the device with limited functionality.
  3. Clear the cache partition: Some devices have a separate cache partition that can be cleared to fix boot loop issues. You can do this by booting into recovery mode and using the appropriate option to clear the cache partition.
  4. Factory reset: If none of the above steps work, you can try factory resetting the device. This will erase all personal data and settings, so make sure to back up any important data before proceeding.
  5. Check for hardware issues: If none of the above steps work, there may be a hardware issue causing the boot loop problem. You may need to take the device to a professional for repair.
It's important to note that the steps may vary depending on the device's model, firmware version, and the region. It's best to check the manufacturer's manual or online guide for specific instructions.
BOSCH refrigerator b20cs50sns is allways running
if its new it will be under warantry, call the shop were you bought it and see what there prepered to do about it.
How to fix logitech keyboard not detected
Follow the steps given below to refresh USB ports.
1. Right-click My Computer icon on the desktop, and then select Properties.
2. Click the Hardware tab.
3. Click the Device Manager button.
4. Click the plus (+) sign to the left of Universal Serial Bus controllers.
5. Right-click the device listed under Universal Serial Bus controller and select Uninstall.
6. Click OK to confirm the removal of the device.
Please note, repeat Steps 5 and 6 until all the devices under Universal Serial Bus Controller are removed.
7. Shut down the computer.
CAUTION: Ensure that the Shut Down option is selected, instead of the Restart option.
8. Wait for 5 seconds and then restart the computer. When the computer restarts, a "Windows has detected new or added hardware" message window will open.
The above steps will refresh the USB ports.
Now connect the USB devices like mouse, video camera, your external usb hard disk...usb hubs...whatever you like and the drivers should install automatically.
Tip: It is allways recommended to connect the main usb devices at the rear end usb port..as they require more power to initate.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
2answers
Lens error,restart camera
This error occured when lens is prevented from properly extending or retracting.when pressure is applied to the lens or the area surrounding the lens while handling the camera.
Avoid applying pressure to the lens and surrounding area:
  • Do not touch Lens while shooting.
  • Make sure the camera is off before the camera is placed back in the case.
If you cannot clear the error code by turning the camera off and then on again then your device need to be repaired.
Rating the solution is highly appriciated...Good Luck.
2helpful
2answers
"lense error, restart camera"
on the camera bottom by the battery theres is a little niddle size reset button press it wit niddle when camera is on then it will restart to factory setting you can try more then ones pushing it.please leave comment,vote,note.thankyou
Camera not staying on LCD display message.
Remove the batteries and externally recharge them . Sometime batteries , in some cases can have a polarity change but then the camera may just not turn on.
First a black screen, then a lens error
For the lens error:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
For the black pictures (after you've corrected the lens error):
http://camerarepair.blogspot.com/2009/05/simple-fix-for-stuck-shutter.html
Note, if you're going to try fix 5a on the above blog page, do it with the camera turned off to lessen the chance of damaging the lens.
Window sizes in ym
It's about windows of yahoo messanger and how to manage them. note my friends cam can go full screen and then press esc to reduce it but the buttons top left of window are not clear enough so instead of making full screen i usully close it down by mistake....is there a keyboard short cut to make it bigger.
1helpful
3answers
I have a document that is stuck in the printing queue that i cannot restart printing or delete prining. i have a lexmark z2300
The only way to clear a print queue when it won't really go away the right way is to be mean. By saying "mean" I would either turn off or unplug the printer itself from the ac power source and when you turn it back on and it goes back on-line it may or may not attempt to print it again or will spit out a bunch of garbage, if this happens then turn it off again. Sometimes this can take a few repeats of doing the same thing over and over again depending on the size of the document and the printer's memory capacity but the problem will clear itself eventually.
Good Luck!
Rich Lilja
2answers
Top Panasonic Cameras Experts
ZJ Limited
ZJ Limited
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
