Question about Yamaha DGX630 - Digital Piano
Only blue light with blank display on power on
I left my DGX630 unused for about 3 months. Two days ago on power on, I got a blank blue screen. None of the control keys is responding. Have you ever had this experience? I need a solution. I am technically inclined. any software upgrade?
Dear Joseph,
I had similar problem with my DGX620. In my case the display sometimes got blue and sometimes worked fine. The cause was a bad contact of the display flat cable.
I opened the DGX620 and then I cut a small piece of plastic film (35mm negative) with exactly the same width of the flat, disconnect the flat cable and then reconnected it using the film on the other side (non contact side) to increase the pressure and guarantee a good contact. No more problems from nov-2012 till now.
Good luck !
Paulo de Tarso (Brazil)
Posted on Jan 13, 2014
6ya staff
SOURCE:
How do i open case to repair power supply
Best advice I can give: Don't. take it to a music shop to let them do it under warranty.
I can appreciate wanting to do it yourself, but (and PLEASE don't take this the wrong way) if you're inexperienced enough to need assistance opening the case, then maybe it's best to let someone else do it.
Sep 25, 2014 | Yamaha DGX630 - Digital Piano
dgx screws are so many..u have to open the speaker covers there are other screws inside...which u can only access by oppening the speaker back cover...you will also have to open the silver screws..all of the behind the cover..all this u r doing when you have separated it from the stand. place it on a mattress in need be to avoid accoustic wear.
Neko lx5
Please find if your piano
is vibrating more than before
If it is not problem
THen go to nearest repairer
if it can be repaired you must repair it
And it doesnt YOU have to change It !!!!
Mar 19, 2014 | Open Labs Used Neko Lx5 Portable Keyboard...
Blue LCD screen
I had the exact problem, mine was a YPG 535 brand new in box I put everything together with stand and FC4 pedal. When i got ready to play just a blue screen and none of the red lights came on and no sound, I notice when i was messing with the on and standby button hopeing it would work the speakers would make a popping noise I personly thought it was a manufacturing defect.....i'm sending it back to have it replace. I never had problems with yamaha products but seems like more and more defects are happing with newer portable grand series!
Feb 24, 2014 | Yamaha DGX 640 Keyboard Arranger
I bought a Xenyx 1202fx roughly 9 months ago. I plugged it in following the instructions of desk to pack first, then pack to mains, but the LED display didn't show. I've heard that there's no...
If the blue power light does not light up then there is a problem with the unit or power supply. As it is less than a year from purchase I would advise returning it to the shop.
Sep 15, 2011 | Behringer Xenyx 1202fx Mixer 12 Input 2...
Hi As recently as a month ago I bought a Kurzweil PC3K8 from sound solutions. On 13/08/2011 I took the keyboard (in a flight case) to a gig. After setting up the keyboard and powering on, the blue light...
Hopefully you didn't take it on a flight as sometimes they use bomb detecting equipment that subjects cargo to either high levels of radiation or high electro-magnetic fields. This can damage the equipment. It sounds like the processor is not running. There usually is a screen contrast control that can be turned enough that the screen appears blank, but usually you can get a sound out of the unit without reading the screen, Look in your user manual for a FACTORY reset or restore and pperform that procedure. If that doesn't work, then repair is in order. If unit has been vibraated during transportation, it is possible a cable has come off inside. Since you just bought this, EXERCISE you warranty immediately.
Aug 14, 2011 | Kurzweil PC3K8 88 Note Performance...
When i switch on my Korg PA800, the screen just show's blank. The screen light gets on but just blank blue. What could be the problem?
Hi, Provided your Korg works as normal, besides the display being blank and lit, I may have the answer. It sounds like the contacts connecting the display have somehow become dirty. This could have happened from something getting spilled on the display. To fix is easy enough if you have a little mechanical aptitude. unplug unit/take batteries out,and disassemble unit to gain access to the main circuit board where screen is located, the screen may be held in place with a tin casing either soldered to board or with prong set though the circuit board and twised on the reverse side to hold in place. After removing this there should be a little rubber strip between the screen and circuit board-this is the contact strip that you need to clean with rubbing alcohol. Clean the screen where the contact strip meets the screen. do the same on the circuit board, reassemble and you should be back in business. I hope this was useful, thanks for asking FixYa, and good luck, Prodzilla.
Apr 22, 2011 | Korg Pa800 Synthesizer
The display on my Technics KN1200 keyboards is blank -I have not used it for some time but when I tried it Yesterday the display is blank -All the other Functions works well. please help Thanks Fritz
Check if there is a contrast setting knob or function. Often the contrast setting gets clobbered and then the display will be blank... worst thing if it is internal setting and you can't see the screen to change it... In that case do a factory reset on the unit. Usually this is holding down multiple buttons when turning power on.
Dec 29, 2010 | Music
My roland xp-50 keyboard is dead.
Ok guys. Just got mine XP50 fixed with the "No Display" problem. The LCD screen was blank without text and only shown orange color. The problem is one of the capacitors on the main board was dead. I have replaced all 3 caps on the main board and the problem is solved and if you are a little handy on soldering, you can do it yourself. The 3 caps you should replace are:
- C901 (I used 16V 330MicroF)
- C65 (I used 5V 4.7 MicroF)
- C 902 (I used 16V 330 MicroF)
Apr 07, 2009 | Music
Yamaha DGX630 - Digital Piano Logo
131 people viewed this question
Top Yamaha Music Experts
Michial Gueffroy
Mike
Are you a Yamaha Music Expert? Answer questions, earn points and help others
