My electric dryer is blowing cold air and it is not stopping. it is continously running
SOURCE: Heat Element is working and drum spins, but no air is blowing?
First make sure that the dryer is vented properly, then check the blower wheel. A common problem is for the center of the blower wheel to get rounded out through wear and tear, allowing the blower wheel to spin on the shaft, thus not spinning at the same speed as the motor. I will attach a photo for reference. Sorry for your trouble and I hope this helped. Best wishes.
SOURCE: the dryer only blow out cold air.
When I turn the dryer on, only cold air blows out. There's no heat. I cleaned out the vents? What do you think is my problem> Thank you very much. K
SOURCE: dryer runs and blows cold air but no heat
If you have a gas dryer.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer is electric..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
SOURCE: maytag DE7500 electric dryer
You need a voltmeter to check the continuity across the two terminals, it should be open. If there is no continuity the limit is bad..
If you found this helpful please leave a thumbs up........
