It started with clicking noise when a dvd was put in, sometimes the disk went "to sleep" for several seconds then started again, but now nothing, "cannot read disk" i tried several times, no luck, even with a brand new dvd.
Follow this steps and fix it. God bless you
Does not play
disc
SOURCE: EMERSON DVD PLAYER CLICKING NOISE..DISC ERROR MESSAGE..HELP!!!
Had a similar problem. Called for support, but was told needed new reader. I took off the cover and manually slid the reader mechanism back and forth a few times. After doing this, tried another dvd and it worked. Apparently it was stuck and not able to move to read the dvd. Give this a try.
SOURCE: Audiovox D1998 portable DVD player will no long read disc.
This of course may not be the exact same thing, but mine did the same thing. Sounding like it was loading, but in fact pressing the open button it I could see the disc not spining at all (normally you would.) With the power off of course. I took all the bottom screws out (where ever the arrow points to a screw) including to the display. There is one ribbon cable easily disconnected. I lifted the mount the DVD sits on and reseated it. I put a disc in it, turned on the power and the disc turned. Great I thought. I reconnect the cable, put the screws back in - and its working.
SOURCE: portable dvd doesnt play movies
Try cleaning the lasers lens with an anti static cleaning wipe. I used " nice'n clean" that I had purchased from Walmart to clean my laptop screen. My dvd player started back playing after gently wiping the laser lens.
SOURCE: Invalid disk message sometimes and machine lock up
coby dvd-233 cd wouldn't spin invalid disc is displayed on the tv please help me solve this problem
SOURCE: Audiovox D1998 Portable DVD Player will not load DVD
you need to clean the disc and make sure it fits in wright if that dose not work try another disc.
