HP Compaq nx7300 Notebook Logo
A
Anonymous Posted on Nov 14, 2012
163 - date & time nor set - HP Compaq nx7300 Notebook
3 Related Answers
CreativeTECH
Creative Tech
  • 1719 Answers
  • Posted on Dec 27, 2010
SOURCE: my computer said "163 time
Date & Time are kept by RTC (Real Time Clock) CMOS Battery, which is usually a coin-cell battery on the motherboad.
As the RTC of your system is dead, it can not keep time.
Therefore, RTC (CMOS Battery) is required to be replaced with a new one to fix the issue.
Let me know if any further clarification is required. Hope this helps! Dont forget to rate the solution!!
CreativeTECH
krishdkiller
Krishnendu Sarkar
  • 384 Answers
  • Posted on Jul 19, 2011
SOURCE: Hp Compaq nc6220 Laptop. there
go to your BIOS setting
There set the current date and time
[while starting the computer , there will be screen showing options keys for bios setting (it will probably be esc or f12 or f2 or f11)]
Anonymous
  • 9 Answers
  • Posted on Aug 08, 2012
SOURCE: 163 date and time not set
have you tried to set the date in windows and it does the same thing? if yes the the battery might be dead. If the battery is fine then you might have e mother board issue! If it is the latter then to save money just change the date and time when you enter the computer - you could even write a batch file that will set your time for you - look up NET TIME SET on google.coim
My hp 6400 lp flashes 163 time &date not set then shut down
Try setting the time in BIOS. It may require a new CMOS battery if the system is exceptionally old, and loses the time again.
1helpful
Error 00161 and 00163 on my IBM Thinkpad 770
Please find below the error on your laptop, i read it on other forum and it says that error 161 is a dead battery while 163 is a timer that was not been set properly.
161
(Dead battery.) 1. Go to Checking the Backup Battery
2. Backup battery.
3. System board.
163
(Time and date were not set.) 1. Set time and date.
2. System board.
Numeric error codes index - ThinkPad 600/E/X
hope it helps..
3helpful
2answers
Hp Compaq nc6220 Laptop. there begin booting one msg "163-time & Date not set". how to resolve this problem.
1helpful
My computer said "163 time
CreativeTECH
2helpful
2answers
Error 163 173 ibm 600e laptop when turned on these errors occur
this error is the battery by the sound of things, you need to replace the cmos battery , then enter the configuation utlity and set date and time, hope this helps
It says there are error codes 163, 8611, and 163 time and date pop up but if you try and pass that it freezes and shuts down again. please help
The 163 error is a BIOS Date & Time error. Go tinto the BIOS setting and set the Date & Time. If you boot up the next time and you get the same error, this is cause by a flat BIOS battery, replace with a new battery.
The 8611 error relates to the PS2 mouse bus connector, try a new mouse or use a USB mouse.
1helpful
2answers
162-System Options Not Set; 163-Time & Date Not Set
The bios settings are being lost during offtime. This is due to the cmos battery being dead. Most units have a round 3-volt lithium battery in a clip/holder. A few use a rechargeable battery that recovers if the unit sees frequent use. Can you verify the model number of this unit?
3helpful
Every time I log on the error173 and 163 appear. What do I do?
Your BIOS backup battery is dead and needs to be replaced.
Go HERE for the manual , page 67.
And HERE is a link to the battery, or google 02k6502 if you dont like the price.
If that doesnt do it , its the motherboard.
Here are the codes from the manual.
163
2. System board.
173
(Configuration data was lost.)
1. Select OK in the error screen; then set the time and date.
2. Backup battery.
3. System board.
Hope that helps.
3helpful
Error showing on boot
The 161 error means the BIOS battery is dead (flat).
The 163 error means the Date and Time is not updating.
The BIOS battery needs replacing and the BIOS settings need to be configured (ie the date & time)
IBM thinkpad 600x
The battery that might be dead is not the main battery. It's the cmos battery, which is a coin cell battery located on the motherborad. It stores the setting in the bios and keeps the date and time accurate. Errors 161 and 163 mean the date and time are wrong. If the cmos battery is dead then, the date and time go back to 1/1/2000 every time the pc is restarted. Thus, you get the "wrong date and time" errors 161 and 163.
Dave
Top HP Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
