Yamaha P-155 Electronic Piano Logo
Anonymous Posted on Nov 14, 2012
How do I reset factory settings on Yamaha p155
Robin Wells
Level 1:
New Friend:
  • Contributor 5 Answers
  • Posted on Nov 16, 2012
Robin Wells
Contributor
Level 1:
New Friend:
Answers
5
Questions
0
Helped
3026
Points
11
Turn off P155
hold top C key down (furthest white key on your right)
while holding this key down, turn on power,
keep holding key down for 3 seconds, then let go.
should default to grand piano 1 setting
Yamaha PSR-S750 61-Key Digital Workstation Keyboard is just showing a logo.
Question edited for clarity.
Try a Factory Reset. Try a power reset first. Disconnect from the mains plug for 15 minutes.
System Reset - Yamaha PSR-S750 Service Manual
ManualsLib https://www.manualslib.com > ... > Service manual
There are two reset methods in the SYSTEM RESET display: Factory Reset and Custom Reset. ... This function lets you restore the status of the instrument to the ...
How to reset Yamaha spx1ooo professional processor
To reinitialize the IS-SPX-1000 unit to its factory default settings:
1.
Unplug the unit from the power.
2.
Push the reset button and keep it pressed.
3.
Power up the IS-SPX-1000 unit.
4.
Wait with the reset button pressed for at least 8 seconds.
5.
Release the reset button.
6.
The IS-SPX-1000 unit will now boot in the factory default mode.v
I have a Yamaha dtexpress. Very old, but works great. Except the snare sound. It is stuck on bongos. Is there a factory reset for the dtxpress?
It's possible to reset the DTXPRESS electronic drum kit to its factory default settings by performing a Factory Reset. Here's how you can do it:
Press and hold the [DRUM KIT] and [SAMPLE] buttons while turning on the power switch.
The display will show "FACTORY RESET OK?"
Press the [DRUM KIT] button to execute the factory reset.
The display will show "INITIALIZING" while the reset is being performed.
When the reset is complete, the display will show "COMPLETED".
Note: Performing a factory reset will delete all user kits, samples, and other custom settings that you have made. Be sure to save any custom kits or settings that you want to keep before performing the reset.
How do i reset the keyboard to factory settings? It sounds really weird right now
You can normally reset Yamaha keyboards by holding down the highest note while turning on. If you want to do a full factory reset see below - remember this may delete all songs etc you have saved to the keyboard memory.
decdbba2-706f-4a8a-afd1-ac3a6264c7f4.jpg dcd670d5-cf98-45e6-87a4-0591820eb4ef.jpg 2c144414-99a6-4025-960d-eaef496036a3.jpg
6helpful
How to factory reset a Yamaha p155 piano
Turn off the p155 power.
Press & hold down the rightmost key (C7) while turning on the power. Once the power is On release the C7 key. It should reinitialize to the original factory setting
Nov 03, 2012 • Music
Yamaha P155 wont power up, replaced power supply w correct one. Any ideas?
Double check the supply... it should be a PA301 which is 16 volt DC at 3.5 amps... fairly hefty one.
Download these schematics:
http://elektrotanya.com/yamaha_psr-1500_3000_sm.pdf/download.html
and
http://elektrotanya.com/yamaha_p-120_s.pdf/download.html
A lot of Yamaha have similar circuits between different models.
When you go to these links, scroll down the page looking for a small link "Get Manual". They will only let you download two a day without registering.
The first of these has the power entry on page 154... the second is on page 60. Both use the 16 volt power adapter. See if one of these schematics is not close enough to your unit to troubleshoot it.
1helpful
I need to reset ( Factory settings) my Yamaha DTEXPRESS IV drum kit. Erase all input and bring it back to factory setting. Is that possible? Many thanks P.
Here is a link to the manual if you don't have one:http://www.dtxperience.com/documents/Manuals/DTXPRESS_IV/DTXPRESS_IV_Owners_Manual.pdf The procedure is on page 35.
The Sustain pedal does not work.
When push comes to shove, a factory reset never hurts.
Assuming you'd like to proceed with a factory reset, follow these steps:
This procedure makes it possible to restore the S08 to the original factory-installed Internal Voices, Multis and System settings.
WARNING: The current settings for all Multis and User Voices will be deleted. If the current settings and data are not expendable, create a backup before executing the Factory Reset.
1) Press the [UTILITY] button.
2) Press the [JOB] button. The 'FactorySet' screen will be displayed.
3) Press the [ENTER] button. The 'Sure?' message prompt will appear.
4) Press the [INC/YES] button to execute the Factory Reset. The 'Completed!' message will be displayed to indicate the procedure has been successfully executed.
5) Press the [EXIT] button to return to the Utility Mode.
1helpful
3answers
Looking for music stand that fits on top of p120
These are sold online at Kraft Music
Yamaha WB53080R Music Rest
Replacement Music Rest for P120, P140, P155, PF500, PF1000
Top Yamaha Music Experts
Paul Bade
Are you a Yamaha Music Expert? Answer questions, earn points and help others
