It goes on, then the screen blanks out for a second, comes back on, and then goes blank again, and then come back on. Seems to happen when the TV warms up. I just replaced the power board because my TV used to pop and shut off after 30 minutes. Any ideas? I'm about to give up on this TV.
Visit the site named 'Electro-help' for more details. Click this link. View it in "Timeslide" or "Flipcard" option, which can be selected from the drop down box menu by the [Sidebar] tag, at the top left corner of the display window. It will make search easy. There are more than 1200 posts to different brand TVs now. Pull up older posts there. Blinking codes to LG Brand TVs are described in detail here.
SOURCE: LG 42 plasma quick blank flash
use other source such as dvd , regular ant or vcr ..use other source for awhile to see if it happens on ther sources .
SOURCE: Loud pop Blank screen 42 inch Viore Plasma
Unfortunately, that board is the inverter board. And for this model the inverter board is only supplied with the the PDP panel. The panel is quite expensive, here's a link if needed:
LG 42PX5D Replacement Part PDP Plasma Display Panel
SOURCE: LG 50PC1DRA POPS AND SHUTS OFF
Your right its a power supply issue and what your hearing is capcitor pop or maybe even a fuse, Well if you know about eletronics sure the new psu is going to be $150 bucks
hope this helps
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
SOURCE: LG 37LC7D 37 in. HDTV
It sounds like a problem in the high voltage circuit. Had a similar TV set which had the same problem. When there's power leaking from the high voltage circuit, these TV's will tend to cycle on and off. Voltage leaks are mostly caused by accumulated dust for the most part.
