I have a 26' LG lcd tv and I had to change the furniture to where it used to be, so I unplugged it from the outlet..... hours later when I got back with the new piece of furniture I put the tv over it, plugged back in and .....nothing !!!!! it just won't turn on, don't even get the red light that you get when you plug it to the outlet....it actually only blinks but the light is not even as bright as it just to be
My TV, same model, went black. The red light blinked on and off. Finally, after unplugging it and trying everything, even the red light went off. The TV had not been on for more than a few minutes so I don't think it got over heated. Is is repairable? My TV, same model, went black. The red light blinked on and off. Finally, after unplugging it and trying everything, even the red light went off. The TV had not been on for more than a few minutes so I don't think it got over heated. Is is repairable?
You can't post conmments that contain an email address.
Your power board has gone bad and is not supplying enough power to start up the inverters. The LED lighting at all shows that you do have standby power, but that is all. You will need to have the power board replaced. Hope this helps.
What exactly on the power board goes bad in this case? Capacitor, relay, etc?What exactly on the power board goes bad in this case? Capacitor, relay, etc?
Check ur clicker like tries new set of batteries.Check the power source like the power outlet?Yes,tries tv unplug,replug the tv power a/c cord plug back like about an hour later for the tv to do resetting it seft back to the factory setting.The tv now should work again.If still have the same problems,tv have problems,new tv bought it under a year old.Call LG take ur tv warrenty repair.
Tries unplug,replug the tv and cable box back like an hour later.The tv now,should reset itself back to the factory setting.The cable box will,reseting itself and updated it softwares.The tv should work now.
Unplug,replug the tv and cable box about hour later.The cable box should upgrade it software and the tv will reset itself back to factory setting.The tv now,should work again.
Reset ur tv by unplug,replug it an hour later.Do the same with the digital box.Go to ur tv menu.Go to AUDIO setting,go down to reset,ur audio should return to factory setting,should have sound return.
Unplug,replug the tv about an hour later.Reset the audio setting back to factory setting.Ushould get audio back.If u not getting sound back than ur main Tuner Signal board have problem.
Just try to reset so picture will come again, some LCD TVs have a reset button. If available and accessible, try using the reset buttons before using the steps below. Using the reset buttons can save time. 1. Unplug the LCD TV power cord from the power outlet. 2. Unplug any connected devices (DVD, Set-top boxes, etc...) 3. Press and hold the LCD TV power button for five seconds. 4. Plug the LCD TV power cord back into the power outlet and turn on the TV. 5. Open the on-screen menu to confirm that the LCD TV is responding again. 6. Turn off the LCD TV and reconnect the devices. 7. Turn on the LCD TV.
Resetting the TV Some TVs have a reset button. If available and accessible, try using the reset buttons before using the steps below. Using the reset buttons can saved time. 1.Unplug the TV power cord from the power outlet for 3 - 4 hours. 2.Unplug any connected devices (DVD, Set-top boxes, etc...) 3.Press and hold the TV power button for five seconds. 4.Plug the TV power cord back into the power outlet and turn on the TV. 5.Open the on-screen menu to confirm that the TV is responding again. 6.Turn off the TV and reconnect the devices. 7.Turn on the TV.
