If you have the instalation disk the best choise is to save your documents and reinstal windows else there are an option in the setting panel(on my winXP)
Download Drivers for Toshiba Satellite Pro L300 Notebook for Windows XP: Toshiba Satellite Pro L300 Notebook is shipped with Windows Vista, which is quite good but most of us dont like Windows Vista. Downgrading Toshiba Satellite Pro L300 to Windows XP requires Windows XP drivers, which you can find on this page. Download all Windows XP drivers for Toshiba Satellite Pro L300. Download Instructions When you click on a download link and a new page opens that is of uploading.com, click on "download free" on that page.
After that wait for the timer to finish and than click on "download"!
Follow my steps: Step1:Download and install Windows Password Reset . Step2:Burn Windows Password Reset ISO file to CD/DVD,or USB. Step3:Put in your newly created CD and remove your Windows Password.
Do you have another valid administrator account which can normally log on? If so, you can log on as the administrator to change the account you forgotten. Or,you can think about the Windows Password Reset , it is very usefull and convenient.
At last,I suggeset you to create a reset disk after reset windows password so you will not afriad forgot windows password any more.
Break windows password, to get more helpful info, u can search the method source: Windows Password Reset Std/Windows Password Reset Pro/Windows Password Reset Deluxe,and have a try.
Follow my steps: Step1:Download and install Windows Password Reset Deluxe. Step2:Burn Windows Password Reset ISO file to CD/DVD,or USB. Step3:Put in your newly created CD and remove your Windows Password.
try log in as 'Administrator' with blank password and go into 'control panel > user' and then try to change the password. otherwise you may also try to look for 'window password reset' software.
si tienes windows xp pro. trata de segir estos pasos en este link. te recomiendo el el 3rd metodo. eso es si tienes windows xp pro. este metodo no te fallara. si tienes windows vista no tengo la respuesta adecuada ahorita
The IBM Recovery Disk that comes with those laptops is set up for Windows 2000, not Windows XP Pro. The answer is No, you cannot use the IBM Recovery Disk for them, if you install Windows XP Pro.
However! You will have a recovery disk, because you will have the Full Installation disk for Each laptop. Windows XP Pro Full Installation Disk.
(Microsoft Users License states "One genuine copy of Windows per One computer" That means you need Two, genuine copies of Microsoft Windows XP Pro)
The laptop won’t POST after removing the memory? Sounds like the memory module (s) need to be reseated again. Removing memory will not reset the laptop. If you want to install a clean Windows XP load, you need to boot from the Windows CD and format the hard drive. Fell free to contact me if you need futher assistance. Your responses are intended to improve the level of service provided. Please rate this solution. Thank You.
