you have to reset the remote for the tv. call the remote manufacturer and they will tell you the code numbers to push and hold for reset while tv is on
If your remote serves multiple units, make sure it's in the right mode for your TV. (not dvr, dvd player, tuner, other source...). If the TV will not turn on manually (with the power switch on the TV), then make sure it's plugged in and there is power at the plug (try a different power source). If your remote has been out of battery power, sometimes it needs to be reset / reloaded with the correct code for your TV. Check your remote and / or your TV manual for the procedure.
If the red light won't come on it is not getting power.First,try plugging it in to a different outlet,or unplug one of the gadgets you know is working and plug the tv in there.You are simply switching.If you know that there is power coming from the outlet and it still won't come on then you'll have to check the cord;don't go much farther than that without expert help.
total dead usually means the fuse---unplug the set for safety and remove back cover---follow power cord just inside and you will find the fuse in a snap in holder--check to see if bad.............if good let me know and I will try to assist you.
Hi, The red light shows there is power connected to the set. The fact that it won't power up is due to a problem with the power supply circuit in the set. or a problem with the switch circuit or the mains power transformer. Regards John Ps don't know why they're giving me these questions, I answer questions on auto's
TV won't turn on • Press the TV button. Make sure the TV is plugged in.• Check the wall receptacle (or extension cord) to make sure it is "live" by plugging in something else.• Something might be wrong with your remote control. Press the POWER button on the front of the TV. If the TV turns on, check the remote control solutions on page 26.• The front panel controls may be locked (disabled). Use the remote control to unlock the front panel controls by selecting the Lock Fr. Panel in the PARENTAL CONTROL menu and press OK (box won't have check mark).Buttons don't work • If you're using the remote control, press the TV button first to make sure the remote is in TV mode.• The front panel controls may be locked (disabled). Use the remote control to unlock the front panel controls by selecting the Lock Fr. Panel in the PARENTAL CONTROL menu and press OK (box won't have check mark).• Unplug the TV for two minutes and then plug it back in. Turn the TV on and try again.TV turns off unexpectedly • Sleep timer might have been activated. Go to page 24 for instructions.• KidPass might have been activated. Go to page 21 for instructions.• Wake-Up timer turned on the TV and no remote or front panel buttons were pressed for two hours.• Electronic protection circuit may have been activated because of a power surge. Wait 30 seconds and then turn on again. If this happens frequently, the voltage in your house may be abnormally high or low. • Unplug TV. Wait five minutes. Plug it in again.
